What would be nice would be a look at the Docking Plan showing the locations of the intake and discharge openings.
Will Rogers
SSBN659
USS Tucson
Yupe. Mirror the MSW and ASW suction and discharges -- one set on each side near the stern.Work continues on Tucson, although slowly as I'm the sole care giver for my wife who had another bad fall but is now doing well with her recovery.
Tucson is beginning to take shape nicely, even though looking a bit rough. And yes, the workbench looks a bit rough too.
Once I clean up the scribing I'll start some of the finer work such as masts, capstan, cleats, strainers, ballast vents, etc.
A question for the audience. My drawing shows only one auxiliary seawater intake and discharge but I suspect there are two each. Can anyone out there confirm which is correct?
Thanks in advance for any help on this.
Will Rogers
SSSBN659Leave a comment:
Will Rogers
SSSBN659
Slick trick with the right-tringle, Will. Very slick! I'll file that away -- much simpler than my deep-sea-nuclear-powered-overkill alignment jig. KISS on display.
DavidLeave a comment:
Girdle the ass-end with a temporary alignment jig. Like this one used to get the tail-feathers right on a 1/96 SEAWOLF.Ok, I need some help David or others too. The alignment I did in the post above is not working for me. After two tries I still can't seem to get the 2 countermeasures aligned to my satisfaction. Anyone have any tips or ideas for an alignment jig?
Thanks,
Will Rogers
SSBN659
Thanks,
Will Rogers
SSBN659
Started work to rebuild voids in countermeasures. First step was to build dams with blue tape to hold baking soda in place.
Then filled voids with baking soda and hit them with CA glue. In the background is a master for the forward dive plane.
Not much progress on Tucson because my wife is recovering from another fall and my priorities have changed, but I'll get there.
Will Rogers
SSBN659
