1/48 3D Printed USS Jimmy Carter
  • SubICman
    Okay, i didnt see a picture in your post Steve.
    In answer to the previous question of a "tooth". A little further research shows that there is a pintle "tooth" bearing at the end of the stabilizer. I can upload a sketch later.
    Originally posted by SubICman
    Steve, whatever you do will be fine. The hull is big enough that it shouldn't be too much of a problem, but if you decide to stay with what you have, it will still work.
    The picture is kinda misleading. The cuts have already been made. Doing a little Bondo work where I joined the tip parts together and then time to do some careful drilling.
    Originally posted by SubDude
    This is what I am going with. Drilling the additional shaft hole in the fixed planes for the tip planes and keeping it straight will be a bi**h but I am going to give it a try. Ehh, it's just plastic.
    (You do know... Steve!... this is pay-back for making me add those vertical stabilizers to my THRESHER models).
  • SubICman
  • SubICman
    Well let's see my references. MY EYEBALLS, I saw Seawolf and JC in drydocks while they were still in Groton. Yes that is a Viginia stern and no it isn't the same as a Seawolf. And to cover the other bases, previously qualified COW/DOOW on 88's and previously qualified pilot/copilot on VAs.
  • Sam Victory
    Originally posted by CC Clarke
    Not sure where people are getting stern shots of the SSN-21 class from, but this is the stern of a VA class with a split stern plane config and it looks completely different from what's being displayed. Here's a VA stern shot:
    CC
    The title says, "... USS JIMMY CARTER". A SEAWOLF class design lengthened for spooky-poo stuff. Where does the VIRGINIA class come in here as source material for Steve's model? Or am I all wrong here?
    VIRGINIA ain't SEAWOLF. Duh.
  • CC Clarke
    Not sure where people are getting stern shots of the SSN-21 class from, (let's see the reference) but this is the stern of a VA class with a split stern plane config and it looks completely different from what's being discussed. Here's a VA stern shot:
    CC
    Practical and sensible as always sir. Makes total sense now that I realize you were displaying different scales in the same post. So based on the 1/96 boat the inboards were not supported by a "tooth" as I call it?
    That's right. The inboards (on my model, anyway, not sure about the prototypes) did not have an outboard bearing, supported in whole by the operating shaft.
    You're spot on, sir. The larger 1/96 model had the room for independently operated stern planes -- one set inboard, the other set the full-flying outboards, each set with their own operating shafts. The smaller 1/144 model only had room for a simplified arrangement which ganged the inboard and outboard control surfaces on a single operating shaft -- a cheat.
    David, did you use a single pivot rod for the surfaces or two? I see what looks like both ways in your pics. The finished model has two but one pic of the raw parts appears to show just one and a support 'tooth' or whatever it's called extending from the fixed horizontal plane?
  • SubICman
    Dave with the win on pics.
    The newer ship control systems could handle it, but i do know that the dihedral surfaces do dampen out the roll and snap phenomena so no need to operate the split planes as such.
    Ok. Decision time... I gotta noodle on this one a bit.
