1/96th Kilo blowing fuses at depth
  • coryhenry
    • Jul 2020
    • 156
    Strange phenomenon that I can't seem to trace. The kilo runs fine on surface and 3 ft under but when it hits 5-6 ft it blows a fuse. I can't imagine the pressure causing that much more drag on the prop. Any thoughts?
    • 13976
    Pressure is deranging the running gear at a bearing or coupler, increasing the torque load. There is relative motion between your motor-bulkhead and the rest of the running gear.
    • coryhenry
      • Jul 2020
      • 156
      So if this is the cause I should be able to stiffen up the drivetrain mounts and relative motion and stop the friction? Fiberglass strips to stiffen?
        Would increase outside pressure cause the shaft seal lip to tighten up too much against the shaft?
          If it's running cup seals, that could be, but at those shallow depths (relatively speaking) I can't see the difference being considerable. More likely Dave's thought. Pressure is distorting things, causing binding somewhere.
