MSD Assistance Needed
  • coryhenry
    • Jul 2020
    • 156
    I have the 2.5" MSD from Bob and I put it in the water today to do a pressure test. I didn't get any bubbles from any of the seals but I did get bubbles in the seam in the MSD fitting. I have attached a picture that shows the seam in the red box. It was a pretty good volume of bubbles, any thoughts?
    Click image for larger version  Name:	MSD help.jpg Views:	0 Size:	58.5 KB ID:	147914
    • 2031
    Cory,
    Inside that joint is an o-ring. That bulkhead is in two parts to make the modular assembly of a cylinder possible. Now that they're joined, they'll never have to come apart. Grind out the seam a bit and slather in some epoxy. That will take care of the issue once and for all!
    • coryhenry
      • Jul 2020
      • 156
      Perfect, I thought that was the answer just didn't know if it would affect the mechanics.
        • 13937
        Take it apart and check the O-ring.
          • 13937
          If the O-ring leaks, the water will migrate through the slight gap in the bulkhead faces, into the over-size holes of the securing bolts, conduit bore, and ballast servo pushrod bore -- you will flood the after dry space. If you just slap glue to the outside gap you will negate your ability to fix this thing!
ID:	147966Click image for larger version
ID:	147967Click image for larger version
          But... what the hell do I know?
          • Scott T
            • May 2009
            • 412
            Could you install the O-ring with silicone sealant. Then if you needed to separate them later you could wedge them apart.
            Prepared for depth charges!
              • 13937
              Click image for larger version  Name:	OIP.i6yAUDX9XRouBr5d4SiElQAAAA?w=197&h=180&c=7&o=5&dpr=1.45&pid=1.7.jpg Views:	0 Size:	18.2 KB ID:	148034
              That would work. But before resorting to that examine, examine the situation: Was the O-ring out of its groove? Was there some crap in the groove to prevent sealing? Is there a tear in the O-ring? Did some ****ing moron forget to install the O-ring during assembly?...
              • coryhenry
                • Jul 2020
                • 156
                What seals the electrical tube the goes through the ballast tank on each end. Is it just a press fit? I think that is where I am getting a leak.
                  • 13937
                  An encapsulated O-ring.
ID:	148138Click image for larger version
                    • 2031
                    I find that gluing one end of the conduit permanently to a ballast bulkhead is a good idea. If you constantly push/pull the cables in and out, it's likely that the conduit can snag and get pulled in one direction or another, parting ways with the seal and causing a leak. If you glue one side permanently, you can still disassemble in case of massive internal repair/refit, but the conduit won't shift on you.
                    • coryhenry
                      • Jul 2020
                      • 156
                      That is exactly what I have done, thanks Bob.
