November Holiday
    cut off 1cm from the middle section of the sail just a few mm before it curves back down. leave the forward portion and the courve itself as-is
    sure. best i go pay you and dave a visit on a regular base ;-)))))
    That looks pretty good. Any chance you'll be in Australia any time soon?
    did a little tinkering n fixing...how`s that look like? Click image for larger version
    Please do. I'm hungry for information.
    id say you take the 2nd sail and shorten it. the fin on the forward deck should be the underice-sonar ONLY fitted on proj 627A, your pictures show K-3 that had its underice sonar in the forward portion of the sail..and K-3 had several sails. your picture should show the original one ( long white stripe on the forward sail). you need to decide what type you want to build. K-3/627 had a round sail both forward AND aft(convex courve). while 627A had a more decent courve forward and more of a streight edge to the stern what looks just like your 2nd sail, which still appears too long. i can give you a picture of the sail of my 627 that gave me the creeps when building it long ago in a galaxy far far away...
    A few observations.
    This is the real thing.
  • DMTNT
    To my untrained eye, your second sail looks a little off. I feel like the front / top needs to be rounded more like the shorter sail in the other picture. If I had to pick between them, I’d go with the original one.
    Yep. Its straight off the newer plans. Neither one looks exactly right.
    Your first sail looks like k 3, the other one like 627A.but that sternward courve needs to be shallower. A continuing curve, no edge towards the sails roof.maybe it is 1cm too long.
    Doing a final alignment check before filling all of the dings, holes and cracks.
    And now a serious question. I've followed the plans that I have to hand and this is the shape and size of the tower/fin/lump in the moddle.
    Given that everything else on these plans is inaccurate, I'm assuming that this tower/fin/lump in the middle is too. It looks wrong to my eye at any rate. Below is a second version made to the shape shown in my newer, but who knows how accurate plans. Up to you guys- what do you think?
ID:	130507 maybe now...
    and the last ones ... Click image for larger version
ID:	130502Click image for larger version
ID:	130501Click image for larger version
    and more... Click image for larger version
ID:	130493Click image for larger version
ID:	130494Click image for larger version
ID:	130495Click image for larger version
ID:	130496Click image for larger version
ID:	130497Click image for larger version
