Building the Zero Bubble Model Design 1/120 Mike SSN
    • Oct 2017
    • 1034
    #31
    Click image for larger version  Name:	20181114_230547.jpg Views:	0 Size:	62.5 KB ID:	145440
    Above the indexing lips, 2018. Rather rough.
    2020: Aquired a Scheppach belt grinder. Nice tool! tested by trimming the indexing lips. Will add filler to flatten the inner face:
    Click image for larger version  Name:	20201014_215613.jpg Views:	0 Size:	68.3 KB ID:	145439
    Also made the Indexing lip for the upper hull, sternwards:
    Click image for larger version  Name:	20200318_224908.jpg Views:	0 Size:	62.2 KB ID:	145444Click image for larger version  Name:	20200320_221645.jpg Views:	0 Size:	63.0 KB ID:	145443Click image for larger version  Name:	20200320_221630.jpg Views:	0 Size:	57.6 KB ID:	145442Click image for larger version
ID:	146066Click image for larger version
ID:	146067Click image for larger version
    Click image for larger version  Name:	20200320_221805.jpg Views:	0 Size:	56.2 KB ID:	145441
      • Oct 2017
      • 1034
      #32
      Time to focus on my favorite: stern tube, propeller and auxillary pods. Initially i wanted to make my own prop from soldered brass, but as i haven`t much hobby time these days, i modified two Raboesch props to work as a tandem pair. Not quite scale, but quicker to produce. So first of all i cut off the hub cone of the inner propeller and enlengthened the M4 thread all the way through. then figured out how much material needed to be removed - and where - to accomplish a press fit between the two units with the necessary angle towards each other`s blades. Marked the spot, installed my milling crosstable into my drillpress and milled a corresponding step contur into the inner props` front and the outer prop`s back. Cut crosswise into the outer`s hub nose and made brass inserts to "Russianise" the look. Fire on the torch ... and done!
ID:	145451Click image for larger version
ID:	145452Click image for larger version
ID:	145453Click image for larger version
ID:	145454Click image for larger version
ID:	145455Click image for larger version
ID:	145456Click image for larger version
ID:	145462Click image for larger version
ID:	145463Click image for larger version
ID:	145461Click image for larger version
ID:	145460Click image for larger version
ID:	145458Click image for larger version
        • Oct 2017
        • 1034
        #33
        Next to do was the stern tube installation. First i had to fill the imperfection at the stern cone.
ID:	145466Click image for larger version
        Brought to shape by wet sanding. i then inserted the tube into the right position and used the shaft with nuts and washers and two wooden discs with orientation lines to ensure the centric alignment. Then mounted the hull pointing upwards and let resin flow into the cone. A small rubber ring at the stern end ensured sealing as well as beeing a placeholder for the propeller`s counter-nut.
ID:	145467Click image for larger version
ID:	145469Click image for larger version
ID:	145472Click image for larger version
ID:	145473Click image for larger version
ID:	145470Click image for larger version
ID:	145468Click image for larger version
          • Oct 2017
          • 1034
          #34
          At the moment i am making the two small auxilary pod propellers. they are made from flattened 4mm brass tube filed into shape with a 2mm stainless shaft pushed through the center and a small hub from 3mm tube. they will be installed in the fixed stowed position that can be seen in the latest footage of the Wreck.
ID:	145477Click image for larger version
ID:	145478Click image for larger version
ID:	145476Click image for larger version
ID:	145475Click image for larger version
            • Oct 2017
            • 1034
            #35
            Soldered, polished and glued in place with epoxi resin:
ID:	145584Click image for larger version
              • Oct 2017
              • 1034
              #36
              Originally posted by Davidh
              Nice work Jorg,
              You don’t need my permission for anything. I am so looking forward to seeing this boat complete, then the Papa and the Delta...
              DavidH
              Thanks David, but i made several new molds from your product. Of course i asked...
              Jörg
                • Oct 2017
                • 1034
                #37
                Hi everyone! I just gave the boat a nice hot soap shower to erase any dust and cleanup the hull after some time (and cutting concrete in the garage was a bad idea,afterall ) just to find several bubbles and uneven spots at the seam line. So i used clear sticky tape to mask the surface and applied fine filler. Wet sanding will follow.
                Click image for larger version  Name:	20201208_213327_copy_1600x1200.jpg Views:	0 Size:	55.6 KB ID:	145744
                  • Oct 2017
                  • 1034
                  #38
                  2 o'clock in the night. Family asleep.party time!
ID:	145843Click image for larger version
                    • 2028
                    #39
                    A superb example of attention to detail and perseverance working with a challenging initial subject. Loving what I'm seeing here! Keep it up!
                      • Oct 2017
                      • 1034
                      #40
                      Thank you, Bob! Am quite happy with the progress of the MIKE now and really looking forward to fully focussing on the PAPA. Experience i made with the 685 will be very helpful. Initial work on the 661 has already been done: hull halves trimmed to fit, limber holes opened, z-cut, sail assembly. However i did some major changes to the sail.
                      Jörg
                        • Oct 2017
                        • 1034
                        #41
                        Hello everyone! Today i continued filling the hull's inside after sanding the outside yesterday evening, this time my nemesis on the Mike, the indexing lips. Keep in mind after i messed up trimming the hull, i had to rebuild a good portion of the edges, including modelling the indexing lips as one integrated part for stability. As i had to learn working with polyester resin back then, i was not able to perform that operation the way i imagined, so there was still work left to do.gaps, bubbles, imperfection. Invisible from the outside BUT i would know they were there. So today i carefully applied sticky tape to the outer surface of the indexing lips, mixed up resin and then wiped it into the gaps from the inside. Put on the upper hull. Waiting for it to cure and repeated the process for the other side. Next i initially wanted to lay up glass, but as there were only about 3 section on each side to fill up, i decided to use fibre-enhanced filler. After curing and sanding back, i'll lay up light glass if necessary. Also figured the sail would disengage from the hull after the recent hot-water treatment ( that also effectively cured any remaining "soft" spot on the resin surface ) and applied filler as well. What happened: i used 24hr-epoxy to pin-down the sail and added poly-resin spots afterwards. Seems i did more "pinning" than actual permanently glueing. Not to mention DavidH describing what glue to use for the kit in the manual-i now learned it the hard way.
ID:	145869Click image for larger version
ID:	145870Click image for larger version
ID:	145868Click image for larger version
                          • Oct 2017
                          • 1034
                          #42
                          Removed the tape today and did some sanding.
                          Click image for larger version  Name:	20201215_220820_copy_1600x2133.jpg Views:	0 Size:	63.5 KB ID:	145904Click image for larger version  Name:	20201215_220715_copy_1600x2133.jpg Views:	0 Size:	55.6 KB ID:	145903Click image for larger version  Name:	20201215_220936_copy_1600x1200.jpg Views:	0 Size:	61.4 KB ID:	145902Click image for larger version  Name:	20201215_220957_copy_1600x1200.jpg Views:	0 Size:	58.0 KB ID:	145900
                          • Davidh
                            • Nov 2010
                            • 719
                            #43
                            Hi Jorg,
                            Looking really nice. So looking forward to seeing it finished. I am back from my holiday and I will probably hit the workshop tomorrow. I have to do an update on the ZB’s progress.
                            Dave H
                              • Oct 2017
                              • 1034
                              #44
                              Hi Dave! Hope you had nice holidays. Did some more filling yesterday and am waiting for a new order if spray primer. Looking forward to you ZB update! Enjoy your weekend!
                              Jörg
                                • Oct 2017
                                • 1034
                                #45
                                Lost some hull detail during the build, so its rescribing for now: Click image for larger version  Name:	20201228_225526.jpg Views:	0 Size:	77.8 KB ID:	146216Click image for larger version  Name:	20201228_235939.jpg Views:	0 Size:	77.4 KB ID:	146217
