Mobius Skipjack in Napa Ca
  • Greevesman
    • Dec 2016
    • 48
    #91
    In post 86 you said 4 oz in the nose was just inside the rear frame of the torpedo nest, Half on each side. I take that to mean in front of the rear frame. 4 oz is 16 1/4 oz weights, half on each side would be 8 on each side.. 2 rows of four going fore and aft? Configuration? What size is your battery? Mine is 5000 mh. Thanks
      • 3769
      #92
      Personally, I would hold off on putting all the weight in until you can get it in water to begin trimming. Your configuration might be slightly different than another person.
      • Greevesman
        • Dec 2016
        • 48
        #93
        I agree but I am trying to get weight in the general areas of the weights in the photos. I am putting in less weights than the photos, then in the water I will adjust by hopefully adding weights. One big unknown are the two lead shot weights that are 2 5/8 x 2 5/8 x 1/2" thick. It appears that they may be quite a bit less than 1/2" at the outer edges. And how much of those weights are lead and how much resin in the interstitial spaces between the pellets? 85% lead? Trying to get close but under while I wait for the subdriver electronics I ordered yesterday.. Thanks for the help. Always appreciated.
        Didn't somewhere in your thread state that you made some more powerful magnetic couplers?
        • Greevesman
          • Dec 2016
          • 48
          #94
          In Post 87 Greenman 407 said the balance point of his lower hull was 13 3/4? from the front cut. Mine came out to 13 7/8" so we are very close.
          In post 91 above .16 lead weights just in front of the lower torpedo bulkhead, 8 on each side?
          Is your battery same as mine? 5000Mh?
            I believe I used a 3 cell Lipo. I'll check tonight
              Yep, 6400mah 3s Lipo. It measures 5.25" long x 1&5/8" wide and 1&5/8" deep. Sorry, I don't own a scale to give you accurate weight. I bought it from Tower Hobbies. Its a ONYX brand 35c , 71 WATT hours, 11.1 volts. Maybe they will list a weight.
              • Greevesman
                • Dec 2016
                • 48
                #97
                That's fine, Mine are 5000 mah so they will be a little lighter. I suspect my lead is a little heavier than yours so we will probably be close enough to get started. I got my electronics from bob this afternoon so I will be starting up again. Thanks.
                  Why can’t I see Photobucket pics? Also, too bad these posts just stop. Love to see end product.
