Mobius Skipjack in Napa Ca
    That system worked out fine. That's been so long ago. I know I picked it up from a local Hobby store. It was a control rod system for RC airplanes. It didn't use a steel cable like most of them but was a plastic splined rod within a plastic splined sheath. Im thinking it was made by "Great Planes" but at this point I cant be sure. Ill look into it.
      Ok I don't see the exact same one that I used but a newer version. Looks like it will do the trick.
      NEW Dubro Lazer Pushrod 36 500 in Toys & Hobbies, Radio Control & Control Line, RC Model Vehicle Parts & Accs, Other RC Parts & Accs | eBay
      • Greevesman
        • Dec 2016
        • 48
        #48
        Thank You! What about the clevis? Does it crimp on to the rod? What did you do with the other end?
          I believe that a Clovis comes in the control rod kit but it might be plastic. I believe that it threads onto a threaded rod that also comes in the package which in turn threads into the control rod ends
            I meant Clevis but I am having trouble with editing. As far as the other end is concerned there should be some pictures later on but I used a Klickon magnet to inhale another magnet on the brass control rod from the Subdriver
              That's engage. Don't you just love spellcheck?
              • Greevesman
                • Dec 2016
                • 48
                #52
                I completed reading thru your thread. Very helpful and informative! I ordered the parts for the sailplane linkage from Du-Bro. When you were painting, was the bubbling you experienced in the hull joint or the putty? Was the hull out in the sun after painting? David told me to wait 2 months after joining the hulls before painting. If it was the putty, it could have been from incomplete mixing of the hardener. I have noticed that I I am always trying to use less hardener to prolong pot life. then it seems like I rush to apply while it is still soft. I found if after the initial application and mixing of the hardener if you scoop the batch into another clean cup, then stir again you will avoid the uncatylized bits of putty in the corners of the cup which can cause bubbles. Also it is easier to mix a larger amount of putty with smaller amounts of hardener for longer pot life.
                  I believe it was the model airplane glue continuing to give off gases during a lengthy curing time. As time went by it eventually stopped therefore I had no further problems.
                  • Greevesman
                    • Dec 2016
                    • 48
                    #54
                    I am planning ahead now that the hull is almost complete. I recently purchased from Bob a VEX 6 channel transmitter which has 4 analog proportional channels controlled by the joysticks and 2 digital channels controlled by buttons which a not proportional.
                    How do most people set up the controls? I have a Phantom 3 drone and it would be nice to not deviate too much from that. (no crashes yet)
                    Left stick could be throttle and rudder, right stick could be stern plane and ballast system. That leaves fairwater planes to the non proportional channel 5. Is that how most folks control the fairwater planes?
                      #55
                      Right stick: up/down -- fairwater or bow planes; left/right -- rudder
                      Left Stick: up/down -- throttle; left/right -- vent/blow
                      Proportional dial (typically flap control): stern planes.
                      • Greevesman
                        • Dec 2016
                        • 48
                        #56
                        The VEX transmitter Channels 5 and 6 are operated by two pairs of buttons on the back of the transmitter. With no buttons pressed these channels send a neutral or centered signal. when one button is pressed the channel will send a full CW or CCW signal. If both buttons are pressed the signal returns to center or neutral.
                        So it looks like on channel 5 I could set a limit and use it for full up or down stern planes. then when cruising along under water the pitch controller would become the proportional control of the sub. Would that work? Or how about a depth cruiser on the fairwater planes?
                        I bought the VEX when there was all the info on the forum about how 75 MHz transmitters becoming unavailable. WFLYs seem to be all 2.4 GHz. Is that what you are using?
                        As always, thanks for your help!
                          #57
                          No, that won't work. Take the three wires coming off the transmitter encoder section -- the ones that lead to the two buttons -- and make those wires up to a 10K-Ohm potentiometer. Or is that 5K? .... Help me out here, Andy.
                          Put a big fat knob on the pot stem and you're in business.
                          • Greevesman
                            • Dec 2016
                            • 48
                            #58
                            What about direction? Up Down?
                              #59
                              Put the knob on the left side of the transmitter case. Counter-clockwise, 'down'; clockwise, 'up'.
                              Duh!
                              • Greevesman
                                • Dec 2016
                                • 48
                                #60
                                Ah, so full scale CW is full up, full scale CCW is full down. Neutral position would be half scale on the POT.
                                Transmitter has one button for full up, one button for full down. Fine so far I guess. But then two buttons for neutral position. the transmitter is expecting a signal from both buttons for position neutral and that would never occur with the POT, so I guess logically that's OK.
                                It sort of seems like the POT needs to be wired into only one of the buttons circuit?
