Cuting stl file
  • gantu
    • 428
    Cuting stl file
    Hello is some aible to cut my stl file in smaller parts the there fit in my 3d printer?
    thanks
    Regards Gantu
    Whatcher chopping? I can give it a shot if you send them over...
      thanks
      gantu,
      If by chance you are using Simplfy3D as your slicing software and you go into advance, they have a setting that will allow you slice a vertical "Z" axis part into as many pieces you need!
      • gantu
        • 428
        Thank you rob i will try these later .
        thank you
        Regards Gantu
        • type7
          • 198
          Prusa slicer will also do a horizontal cut and can then be exported if you use a different slicer on your printer.
