Alumilite with David Merriman
    • 13405
    That's what they say, but if you half the times, you have a more realistic idea of how long you have to get the filled tool into the pot. I use the so-called slow cure stuff, the RC-3. I buy mine by the two-gallon kit. In fact, I have a days full of casting ahead of me.
    Leave me alone, damit!
    • Tom Spettel
      • Dec 2009
      • 50
      well Dave.... had a friend do some pressure castings last weekend and they dident have any bubbles in them but the castings were distorted
      from the air pressure.. he was using 140 psi... seems a little to high... whats a good pressure @ 5280ft alt?
      BTW was at the hobby shop and was looking at some of the cast resin parts for 1/48 and 1/32 aircraft made by "Aires" sweet castings!!!!!
      no bubbles!!!!!!!! how do these guys get such small detail to turn out good???
      Tom
        • 13405
        Your pal didn't have a problem with the pressure (more is good), he had problem with his method of clamping the tool halves together -- that's what distorted the parts.
        All detail quality is driven by quality of the master and handling of the tooling rubber during mold fabrication; get those two things right, and you can capture any detail onto the part.
