Couple of videos taken at the Brockwell Dive-in last Sunday.
Tags: None
Very good, i wondered how that video would look. would be good to make the trailing system more invisibleNext time someone points out it takes 42 muscles to frown, point out it will only take 4 muscles to b1tch slap them if they tell you how mnay muscles you need to smile:popComment
Try some 20-50lb test fishing line - almost invisible and if you attached it from the sail and on the other end attach it slightly offcenter, I think you'd fix the problem. Imagine a horse pulling a barge on the canal. They never put the line on the bow, it was set back alongside a few feet, so it steered itself away from the bank.Stop messing about - just get a Sub-driver!Comment
David,Who is John Galt?Comment
That's food for thought, I'll forward on your suggestions to Chris. I'll probably have a go myself too, as I will have the 808 cam watertight housing finished shortly- in time for the Summer Dive-in when we get a pool for the whole weekend to muck about in. These shoot in 720P HD, so the picture quality should be better than Actioncam and Flycamone2, and they also have a much wider field of view.
AndyComment
It's a two piece GRP teardrop enclosure with a radial o-ring seal at the widest point. The masters are waxed and PVA'd, so should be moulding this week.
I plan to do a few (your name is on the list) and supply them on a limited basis as a pair of mouldings much like a miniature ballfish, leaving the builder to fashion a sealing ring and fixing mechanism. I have four 808 cams now, three 'version 3' standard definition cams, and one 'version 11' 720P HD cam.
The idea is to hand them out at the Dive-ins so that people can clip them on to their boats. With a much smaller footprint- under half the wetted area of an action cam- and a shape optimised for streamlining I'm keeping my fingers crossed that these will work well on smaller models where the Actioncams might upset the boats handling.Last edited by Subculture; 04-02-2011, 02:53 AM.Comment
My idea was to resin/glue in a brass threaded bush into the bottom compatible with a tripod mount- think they're 1/4" UNC thread from memory, will have to check.
Then you could use a variety of ready made adapters or grow your own, adapt Actioncam stuff etc. I thought the best way to fix it to a generic sub hull would be to use releaseable zip tie, cheap, readily available, doesn't add weight or bulk. The other possibility are those velcro straps I see in hardware stores, but they're rather more expensive and also more bulky.
AndyComment
