Couple of videos taken at the Brockwell Dive-in last Sunday.
    Ramesh's new Engel 212, sans paint.
    Chris Netherways scratch built Grondin, including DIY R/C.
    Couple more, this time by Chris Netherway filmed from his Grondin and Vanguard class.
      • 651
      Very good, i wondered how that video would look. would be good to make the trailing system more invisible
        I agree, although by using a thinner cord, you run the risk of it getting caught up in the prop.
          Try some 20-50lb test fishing line - almost invisible and if you attached it from the sail and on the other end attach it slightly offcenter, I think you'd fix the problem. Imagine a horse pulling a barge on the canal. They never put the line on the bow, it was set back alongside a few feet, so it steered itself away from the bank.
            • 14013
            Like the fly-around body used by the ALBACORE during self-noise studies. Mike's idea here has merit.
              That's food for thought, I'll forward on your suggestions to Chris. I'll probably have a go myself too, as I will have the 808 cam watertight housing finished shortly- in time for the Summer Dive-in when we get a pool for the whole weekend to muck about in. These shoot in 720P HD, so the picture quality should be better than Actioncam and Flycamone2, and they also have a much wider field of view.
              Andy
              • Mankster
                • 41
                It this a one off camera housing or can you make somemore?
                  It's a two piece GRP teardrop enclosure with a radial o-ring seal at the widest point. The masters are waxed and PVA'd, so should be moulding this week.
                  I plan to do a few (your name is on the list) and supply them on a limited basis as a pair of mouldings much like a miniature ballfish, leaving the builder to fashion a sealing ring and fixing mechanism. I have four 808 cams now, three 'version 3' standard definition cams, and one 'version 11' 720P HD cam.
                  The idea is to hand them out at the Dive-ins so that people can clip them on to their boats. With a much smaller footprint- under half the wetted area of an action cam- and a shape optimised for streamlining I'm keeping my fingers crossed that these will work well on smaller models where the Actioncams might upset the boats handling.
                  • Mankster
                    • 41
                    Good stuff...... "Bring your own Micro SD card and borrow a SubCam for the day..." Good selling feature.
                    Whats the mounting system like?
                      My idea was to resin/glue in a brass threaded bush into the bottom compatible with a tripod mount- think they're 1/4" UNC thread from memory, will have to check.
                      Then you could use a variety of ready made adapters or grow your own, adapt Actioncam stuff etc. I thought the best way to fix it to a generic sub hull would be to use releaseable zip tie, cheap, readily available, doesn't add weight or bulk. The other possibility are those velcro straps I see in hardware stores, but they're rather more expensive and also more bulky.
                      Andy
