MK148 ADCAP GAS TORPEDO: Design, Build, & Test Validation
  • QuarterMaster
    • Sep 2015
    • 1240
    1:48 SCALE USN MK48 ASW/ASUW Heavyweight Torpedo for
    RC Submarine operation.
    v/r "Sub" Ed
  • TINFISH
    • Apr 2019
    • 64
    Very nice design and execution Ed. Like your approach
    Look forward to seeing these work in person.
    Mike
    • Monahan Steam Models
      • 755
      Ed,
      Watched your recent video on the “NoCap” test you posted on the Subcommittee FB page. Yes the butane sucks. Pressure is too low for larger torpedoes. Propel works much better. These torpedoes I designed some months back are also 1/48 scale and here’s a video launching one with a short fill through the forward fill valve. They can also be filled at battery in the tube but I ditched that in later designs as I found it was easier filling them outside the boat, then loading them in the the tubes afterwards.
      Nose weight isn’t an issue if you use ronson butane fill valves in place of shrader valves. I also use the central gas pick up tube as a stay rod for the forward and aft propel tank bulkheads to keep them from blowing out the ends of the central aluminum tank body. The nose at aft sections of the gas torpedo are the same resin prints from the work I did with the G7e counter rotating prop electric torpedoes.
      Nick
