LIPO Batteries in model subs-consider this
  • Bob Gato
    • 898
    Picking the perfect LIPO battery for a model sub can be daunting...Usually the choice is based on MAH value and voltage. The size and weight comes into play but is rarely considered-if it fits-its a go. The "C" rating is, in my opinion is a big factor also. C is the amount of amps that the battery pack can deliver in a brief draw (as in a fast electric boat or a ducted fan plane executing a go around) without destroying the pack. Subs rarely draw many amps (most draw less then 10-15amps) So why would you a want a 2200mah battery with a 50c rating-when they produce 2200mah batteries with a 35c rating that are 2/3 the size and weight. The Amperage (and watt hour) output is the same in both 2200 mah batteries(same run time) -remember that the load determines the amp draw (under 10-15 amps). The only way you would need 50 amp output is to feed a short circuit or fire! Bigger is not always better ( unless it means more watt hours and run time and C rating doesn't give runtime) ...BG
  • QuarterMaster
    • Sep 2015
    • 1244
    Originally posted by Bob Gato
    Bigger is not always better...BG
    So basically you're telling me Bob, I shouldn't try to get my 1:48 Scale FLT II LA up on plane??
    v/r "Sub" Ed
    • Bob Gato
      • 898
      Not unless the captain wants to waterski..
      • Bob Gato
        • 898
        -It will fit in the dry compartment so I am going with two parallel 2200mah lipos protected against back charging by two 15 amp Schottky diodes.
        Click image for larger version  Name:	PB170001.jpg Views:	0 Size:	40.0 KB ID:	166916
        Click image for larger version  Name:	PB170003.jpg Views:	0 Size:	46.6 KB ID:	166917
        Click image for larger version  Name:	PB170002.jpg Views:	0 Size:	47.1 KB ID:	166918
