A Little Something I Cooked Up
    • 898
    The voices in my head said "Pilot G-2" ballpoint pen...I was always intrigued how these pens screwed together with a VERY coarse angled thread-only two turns to open..
    Produces a nice streamlined watertight screw together capsule to house a servo connector and I'm sure it will stay watertight past "crush depth" of most if not all of these model subs.
    https://www.rcgroups.com/forums/show...65&postcount=8
    Very cool idea! So do you have slack wire bundled up in there so that you can make up the connection and then stuff it inside to close up?
      • 898
      No Need-The housing now(after shortening the threads) only takes a turn and a half to close and tighten-that 1/2 inch of wire between the epoxy seal and the connector is plenty to make the twist-that's why I said line up the pins into the holes, now the connector holds position, then turn counterclockwise (that puts a 3/4 reverse twist in that 1/2 inch of wire)-now screw together and that reverse twist comes out and becomes a positive 3/4 twist that takes up enough space to allow the connector to fully mate being pushed in by the slightly smaller male side of the housing-The measurements are not ultra critical but you have to be close.
        • 898
        Keep in mind that the only travel needed to be taken up by the wires is the initial 1/32-1/16 of engagement to align the pins and allow you to then twist the wires-all other travel is absorbed by the distance the pins go into the female sockets-no need for any extra and stuffed wires...
