David Merriman's Garage Sale
  • reddevil
    • Jun 2009
    • 346
    Would it be possible o have a tube and end caps for the REVELL VII C? I mean, the full empty tube and the end caps. How about sending them overseas to Spain? Wait for your figures.
    • Buellman1
      • 93
      Do you happen to have a tube and parts to fit a 31" total immersion nautilus? I'm trying to source something for my dad, I currently have a type 212 driver for mine. The 2" parts n tubes look workable if nobody else has taken them.
      Thanks,
      Gene
        Thanks,
        Gene
        I think so, but I'm checking with HWSNBN
          • 3452
          Ditto Mike.
          • subkraft
            • Oct 2009
            • 28
            Is there a 3.5 inch motor bulkhead anywhere in there? Would complete a subdriver lying around here.....thanks.
              One or two props?
              • subkraft
                • Oct 2009
                • 28
                Either would be fine. Not nominated for any particular project at this stage. Just want to make it complete. Thanks
                  Great News!
                  I have all David's old WTC molds for end-caps and bulkheads.
                  I intend to produce from these in epoxy, so if you are looking for 2.5" 3" and 3.5" end caps etc. let me know
                  Most end-caps will be $10 plus $5 is you want a gear reduction box. There will be no gears, O rings, shafts, seals, motors etc. These are available at www.sub-driver.com
                  I still have lots of Lexan, so let me know what you want and I'll sort through it. I need dimensions, so please don't say "I want it for a doo-hickey boat" because I probably won't have a clue and then I'll have to bug Merriman. That will only annoy the crap out of him, and I'll have to listen to another tirade!
                  This should make all those other lesser mortals flogging end-caps feel ill.:-%
                    I have several complete units. Tell me exactly what you want
                      • Click image for larger version
ID:	84485Click image for larger version
                        Some of these units are complete with motors, servos, seals and gas system installed. The others I have the parts for. Now if only I could figure out what boats these could be used for.
                        I also have plenty more parts to make the same sort of thing up for longer lengths of cylinder. It's a 2.5" cylinder.
                        These are ideal for the Trumpeter 1:144 Seawolf and similar sized models.
                      • subkraft
                        • Oct 2009
                        • 28
                        Let me check tonite.
                        Come back tomorrow with the details
                        • subkraft
                          • Oct 2009
                          • 28
Name:	3.5 inch tube_post_1.jpg
ID:	84527This is the 3.5 inch subdriver.....need motor unit, endcap, single screw. Guess it's fairly old but has cool adjustable volume ballast tank. Thanks for looking.
                            [ATTACH=CONFIG]24168[/ATTACH]This is the 3.5 inch subdriver.....need motor unit, endcap, single screw. Guess it's fairly old but has cool adjustable volume ballast tank. Thanks for looking.
                            Got it! I'll work one out tomorrow!
                              Here's what I have, a complete Motor Bulkhead and tray with new seals and a Groupner 550 7.2 volt motor. Spare screws included for the tray.
                              $55
                                How did HWSNBN do the adjustment of the ballast tank?
