Skipjack fittings kit
  • coryhenry
    • Jul 2020
    • 156
    Does anyone happen to have a Merriman Skipjack fittings kit? I got ahold of a Mobius kit and wanted to put it in use.
    Check with Bob. He still shows them for sale. I think he makes them up after you order.
    • coryhenry
      • Jul 2020
      • 156
      Unfortunately he is out and no plans to make more :(
        In that case, go to https://www.rcgroups.com/boats-fs-w-104/
        and place a wanted ad.
          R & R Model Engineering has fittings kit for the Skipjack
            http://www.rcsubs.co.uk/revellskipjack
            Not really. No dive planes, rudders, WTC cradles that will work, etc.
                I was just going to mention this article. Using the provided parts will work with slight mods.
                • jphatton
                  • Jan 2021
                  • 112
                  I converted a Revell Skipjack using the R&R conversion kit, which was my first RC sub build.
                  On the whole it is a reasonably complete conversion kit for RC, using the Revell/Mobius kit dive planes and rudder and includes all fittings and a WTC with pumped tank and snorkel. I had one of the earlier production conversion kits, but the design has been improved with time including a polycarbonate ballast tank along with some added items such as magnetic hull closing in the nose (I made a similar setup using styrene sheet and small magnets). At some point when I find time I will try to post a retrospective build log.
                  • coryhenry
                    • Jul 2020
                    • 156
                    Thanks for the suggestions. I already have a WTC so its really the dive planes and the connections but it looks like the model parts will work so I will just build from scratch.
