Wanted: Matt Thor 637 class sub
  • Navy2000
    • Jan 2018
    • 42
    Looking for a Matt Thor 637 class sub hull and fittings. I would like to get an untouched hull and fittings. No other items are needed.
    Duane
    • 13968
    Work'n on it.
    • Navy2000
      • Jan 2018
      • 42
      Hi Dave
      Will these also be expoy resin like Matt's were and not the normal fiberglass resin? I have one of Matt's hulls already plan on making the Parche.
      Duane
        • 13968
        Originally posted by Navy2000
        Hi Dave
        Duane
        I've made a test shot of the hull using epoxy laminating resin and it turned out OK. I assume, once I turn the tooling over to Bob, that they will do the same for production units of the kit.
          • 2043
          Absolutely. Epoxy glass hulls and cast resin appendages.
          • Navy2000
            • Jan 2018
            • 42
            Let me know when all is done.
            Duane
              • 2043
              Yep.. you and everyone else waiting for one of these awesome kits! There's a slough of people who have expressed interest. We'll be busy knocking these out once the tooling arrives.
              • Navy2000
                • Jan 2018
                • 42
                The 637 class subs were small, but it was fun serving on one while I was in the Navy. I served onboard USS Puffer SSN 652 from Jan 91 to Nov 93. Like I said before I will be building the Parche inwhich I seen pull into San Diego many times.
                Duane
                • Navy2000
                  • Jan 2018
                  • 42
                  Hey Bob
                  Is there a guess of what the kit price will be? Just wondering so I can put a few bucks on the side for the kit. Working on to many models most of them being the target type.
                  Duane
                    • 2043
                    It will be in line with other kits of the caliber of work of Matt and Dave. I'm guessing mid to high $400's, but I haven't locked in until I get the tooling and analyze labor and material costs to produce. It will also be affected by the peripheral components I'm able to source, be that props, shafts, dry transfers, blueprints, etc.
                    • Navy2000
                      • Jan 2018
                      • 42
                      Not to ask to many questions is the hull based on a long hull of 302 feet or the short hull of 292 feet?
                      Duane
                        Work'n on it.
                        I thought you retired.
                          • 13968
                          I have. But this project, and a few others, are commitments still outstanding to Bob and a few other people.
                            I always knew you were a stand up guy. A *******, but a stand up guy.
                              • 13968
                              Leave things better than you found them. I blame good parenting.
