Merriman Fittings Kit for Type VII
  • ir3aus
    • Mar 2010
    • 56
    Looking for a fittings kit for the Revell Type VII by Dave. Bob has none available and was hoping someone may have one and is willing to part with it.
    There is a fine line between hobbies and mental illness!
    • 12313
    Sorry, no longer in production. Should have bought one when the buying was good.
    • ir3aus
      • Mar 2010
      • 56
      David, any chance you have the lengths of the 5 removable deck supports in your notes. I could probably measure them up but if you have the lengths it would help considerably.
      Thanks,
      Iran
        • 12313
        Thanks,
        Iran
        I think I can cobble some parts together for you. Give me your mailing address. dmeriman@aol.com
        • ir3aus
          • Mar 2010
          • 56
          I am at the point of ballasting the Type VII. The Cabal report indicated that you used 6oz in bottom of the hull as far forward and then 4 more ounces as far forward in the bottom of the hull. Am I correct in that you used a total of 10oz of ballast to get the boat to the waterline. It is not clear. I do not have the cast lead pieces from Caswell so I will be using lead shot to make up the weights. Could you let me know if the 10oz total is correct and exactly where the ballast should go.
          Thanks,
          Iran
          • Minorcan
            • Jul 2019
            • 9
            Alas, all good things must pass. I’m in the process of building a new Revell Type VII to replace one that was totaled in a moving accident. Professional movers, I don’t think they are as good as they were thirty years ago. I salvaged the WTC but not the hull or fittings. It had a set of Dave’s fittings. They really saved a bunch of work.
            Ir3sub, I’m in the hull assembly stage now like you. Good luck, show us some pics when you get a chance.
              • 12313
              e-mail me. dmeriman@aol.com
              • ir3aus
                • Mar 2010
                • 56
                I scratch built all the pieces to put this together. It was quit an exercise. Dave did a great job on designing the parts for a sub this small. I have a thread on RCG under submarines that just show the problems of getting the rudders and dive planes installed. I will probably post the installation of the snorkel valve in that thread.
                  • 3547
                  Yeah you better! I will try not to push you too much! Build threads help so many!
