Neptune submarine light system and new improved conning tower
  • deepseadiver
    • 296
    MY neptune improvments added my own personnal touch with the new version conning tower instead of a plastic clear dome cap scratch built project. David M you
    should be able to appreciated something like this because its hand made?
    What do you think.
    JIm
  • deepseadiver
    • 296
    more pictures of the tower
    • deepseadiver
      • 296
      last picture i also have a video attached so you can see my strobe system working along with my new search light system all installed. A pool video soon.
      Jim
      illumination rating over 1,000,000MCD times two since i have two lights on both sides . Just for kicks they were tested down to a 1000 feet wow!!! How cool is that taken down in a rov sub by a freind that works for scripps of oceanography in san deigo, CA was a freind of Jacque cousteau what a incredible man he was .
        • 1768
        I like it a lot! Suits the boat and you did a great job building it. I love the lights as well. Are those homebuilt light pods or did you retrofit something else?
          • 3545
          I like that you put your touch to it and it came out so well!
          Excellent!
          Tom
          • deepseadiver
            • 296
            thanks trout for the nice comment
            Jim
            • deepseadiver
              • 296
              Hi sub human,
              I appreciate the words spoken from a true hobbiest that can appreciate home made projects
              the lights are from a vender, that builds them on the side for the neptune and helped me out with the lights only . I purchased the sub from a private person got a bad deal but i fixed the sub it works perfect now. Planning to post a pool video, soon.
              Jim
              • deepseadiver
                • 296
                live Camera for the Neptune
                PS Im looking for a camera that can hook up to the Neptune and has live video feed to the radio and i want to be able to record onto a dvr if possible capture what iv'e seen if i want to any suggestions would be great.
                David Merriman, do you have any comments on the sub, camera equipment some type of video, feed from some glasses that can see live video. Maybe ran by a cable from the sub, to the vision piece. Polyphemus has the cable which i like but the viewing screen, is very small and the unit does not even record nothing . I need something better then that if im going to spend $250 or more. I can place any type of HD camera on top of the sub and go for a dive and hope i caught something good on video that sucks going that derection
                ok David the master of submarines, talk away im all ears and eyes .
                Jim
                  • 12256
                  You've already got a conduit for the camera signal in the form of an umbilical. Use it. You can patch off the plug into your virtual goggles and into the input side of a portable recorder, now-a-days an SD card.
                  • deepseadiver
                    • 296
                    Hi David,
                    this sounds great do you guys at Caswell sell the cable i need for the original camera cable connection you were talking about that the Neptune has up front, its a big fat round screw off cap.
                    I am just curious how the cable attaches to it while making a water tight seal, it's just a big hole once you open it up ? The cable is about 15 feet long if i correct. This way i can purchase the virtual goggles, and the cable which i think you do sell can you help me out on this one also .
                    best Regards
                    Jim A
                      • 2119
                      A lot of underwater videos are akin to watching paint dry- a camera fixed somewhere on the boat, and a great expanse of bugger all in front, aside from the occasional inquisitive fish.
                      It gets a lot more interesting if you can get a couple of other boats in the water, and track one another around the lake/pool/pond, the other thing that works is to put the camera in a pod/cylinder of its own, and tow it behind the boat.
                      • deepseadiver
                        • 296
                        Hi Subculture
                        these are great ideas you mentioned do you know how the viewing cable attaches to the front end of the Neptune after you take off the front silver cap were the camera is located and a cable comes from that area to your viewing screen of choice. I need someone to explain to me how the cable attaches and makes a water tight seal. Some suggestion or instructions would be nice to have
                        cheers
                        Jim
                          • 2119
                          I can't give any advice regarding camera installation in a neptune- I don't have that boat or the camera system you are trying to fit into it.
                          • deepseadiver
                            • 296
                            ok thanks anyways subculture
                            David M. and Mike C you should know what i need to buy and how does the camera fit in the hole i have mentioned about how does it seal itself. Is there some kind of camera system lug set you buy to fasten and make the cable water tight .
                            Jim :)
                              • 12256
                              I've never touched one of those things. Can't help you.
