I think my viper 10 blew up
  • roedj
    • Sep 2008
    • 563
    #46
    Originally posted by Kazzer
    Maybe you should simply send ALL the units back and we'll ship them to Mtroniks along with any others that had this problem. So David should send his to me as well.
    Mike,
    Thanks for your clarification.
    Just to make sure we're all on the same page here, do you want me to send the unopened units back to you at Caswell? If so, is there a RA#?
    Dan
      • 12318
      #47
      Dan,
      I'm sorry about my tardy response and action on this matter. I completely forgot my promise to you to get your turned in unit off to MTroniks (along with the one that failed on me). Tomorrow I'll box both up with a cover letter explaining our observations.
      Very sorry about this oversight.
        • 2848
        #48
        Originally posted by Merriman
        Dan,
        Send them to me David. I'll send them ALL back to Mtroniks in ONE hit and issue credits/replacements etc.
        • roedj
          • Sep 2008
          • 563
          #49
          David & Mike,
          Whoa big guys, whoa.
          I have not sent any Mtroniks ESC's to anyone. I have not had any Mtroniks ESC failures. I DO have at least 3 unopened Viper 10's in my possession. I was just wondering (out loud, I guess) if I should build a test rig and run them all for awhile to see if they smoke. Then Mike said, "Send them back to me." Me is Mike, I think.
          OK, ball in your court, what do I do next, if anything?
          Muddled in Michigan,
          Dan
            • 12318
            #50
            Ugh! Sorry, I'm addressing the wrong guy here. Another member send me (at my request) his toasted Viper 10 -- I got you confused with him.
            As to your Vipers. hook them up with a 15 or so quick-blow fuse between the battery and input side of the ESC -- I normally don't do that, but it will prevent a cook-off if you have a bum ESC.
            • 639mpa
              • Nov 2010
              • 68
              #51
              I am the other guy. I sent it up. I had a 10 Amp sloblo fuse between the battery and input side of the esc and it still went toast. That's what has me stumped. I killed the mission switch asap but it was too late. I installed a new esc from spares and all was ok. Also I made no changes after it went toes up and the new one is fine except for the bec that came off the side but I resolved that problem which I'll post tomorrow under the d&e section on my 2.5 wtc.
                • 2848
                #52
                Did we do anything about this? I was under the impression all these defective units had been replaced.
                Lets carve this in stone now folks. Send defective ESCs etc to CASWELL Inc with a note explaining what happened, invoice #, etc. We'll fix you up with a new one from our inventory and deal with Mtroniks. That way was have a chain of command and the paperwork will flow better. Mtroniks and I will resolve the exchanges etc. so you folks won't need to mess with sending stuff to England.
                • xilence
                  • Jun 2011
                  • 2
                  #53
                  Hello.
                  I"m from the Netherlands and in my search to an answer why I toasted my ECS Mtroniks viper 10 I came on this forum.
                  My English is not very well, but I will give it a try.
                  I ordered recently four viper 10 ECS for my project in England and build them in my project.
                  Each ECS has his own (little) 12v 25 mm gearmotor like this one Click image for larger version
                  Ouput power 10w, no load, 004 Amp, at maximum efficiency, 0.17 Amp.
                  Al of them are fused with 5 amp.
                  On several tests everything goes well, but when I build them in my project and connect the power again I saw a very little spark, nothing els like a burning smell or something like that. When I want to test it I noticed that one function doesn't work anymore. The ECS which connect to this function seems completely dead and extremely hot, and no red or green light. I can't see any damage om the ECS whatsoever.
                  The ECS are 4.8 to 12v, I use a 12v 7a lead acid battery.
                  On the moment when this happened I got 12.6 volt. Was that to much? Could that be the problem?
                  What is the really maximum volts they could have?
                  I know that a 3 cell lipo has also fully charged 12.6v. People use them all the time for this type ECS with no problems.
                  I ordered a new one, but I'm afraid to connect it to my battery again before I know what the maxmium volts they could have, maybe someone here has some experience with it.
                  Or maybe do I have also a bad ECS, like mentioned here.
                    • 12318
                    #54
                    Xilence,
                    Just got word this morning from an MTronik's technical representative about this very issue. He's sending me a 'new' style of ESC for evaluation that, if it checks out, will replace the Viper 10's in our Caswell catalog.
                    Steve (the MTronik's guy) did report that of the many units they have sold, that particular ESC did not evidence any failure reporting above the norm. Anyway, it may be a moot point as it seems they have dropped production of the Viper 10.
                    Stand by, I'll post findings and the alternative ESC here when we get this worked out.
                    My own opinion is that there was a bad lot of this ESC that got out of the plant and they have, over time, found their way into the hands of guys who actually use them and suffer a failure. **** happens as they say.
                    Other than this single item problem our experience with the quality, price, and availability of the MTronik's line has been nothing short of outstanding.
                    Also, the voltages and load you have applied to your ESC is well within its operating limits. Me thinks you have some bum units there.
                      • 1777
                      #55
                      I just had TWO of these explode on me. One came from OTW and one was in my parts bin. They both exploded in a like manner (yes.. literally exploded). They were pulling power from the same source, however they were driving two different motors, one the main drive motor and one a little Graupner motor for a bow thruster.
                      Smoke billowed out of them and they literally spat gunk all over my shiny WTC innards. Both were working perfectly up to the time they died.
                      Weird as heck.
                        • 1777
                        #56
                        Hmm... now that I think of it.. would it be bad that each was running a BEC circuit?
                        • xilence
                          • Jun 2011
                          • 2
                          #57
                          Merriman
                          Thanks for your answer.
                          Do you meant with 'bum units' that they are suspicious?
                          I'm not so happy with that idea, now I have three left which be can toasted. :(
                          They are not so cheap that you can trow them away and order an other brand.
                          Beside that, I'm dutch, we folks trow nothing away. :biggrin:
                            • 12318
                            #58
                            Originally posted by xilence
                            Merriman
                            No, don't toss the Viper 10's you have. Send them (and the fried units if they are still in hand) to Mike Caswell for replacements -- we're working with MTronik's right now to replace all Viper 10's with ESC's of an improved design and higher capacity.
                            Thanks to you, Bob and the others who have brought this issue to our attention -- we can't fix what's wrong unless we hear from you guys in the 'field'.
                              • 12318
                              #59
                              Weird as heck.
                              Bob,
                              These Nuked ESC's you pictured: are they the now infamous Viper-10's?
                              You must be madder than hell about this. They popped IN your WTC. Ouch!
                              They popped at the same time? Did they pop at power-up or after some time after power-up?
                              I know you use a lot of the Micro-Marine 10 ESC's -- ever have a problem with them?
                              Send your fried Viper-10's and unused Viper-10's to Mike for replacement -- excluding those bought from another source, of course.
                              • roedj
                                • Sep 2008
                                • 563
                                #60
                                D & M,
                                Clarification please. When I last visited this issue you were asking for Viper Sub 10 ESC's that had blown up to be sent back. It now appears that you want ALL the Sub 10's back regardless if they are "all blowed up" or not. Is this correct?
                                I'm asking because I have 3 Sub 10's in the original package, never used, that were about to go into 3 separate sub's this summer, one of which I hope to take to the Sub Regatta in early August.
                                Bottom line: I need at least one comparable ESC that probably won't go poof when I fire it up by the end of June.
                                What's my best course of action here?
                                Dan
