ADF2 default sensitivity setting
    Kevin, in your instruction manual on the ADF2 the section under "sensitivity adjustment" states that the default sensitivity setting is three for the most sensitive. Does that mean that after you turn the sensitivity setting down to one, you have to reset it everytime you power up your submarine because the default setting puts it back to three?
  • KevinMc
    • 305
    Hi Mark,
    I'm guessing you'll have figured this out by now, but... No, the "default" is only indicative of how you'll find it when you take it out of the package. Once you set it, what ever you set it to will remain.
    KMc Designs
      Thanks Kevin. Unfortunately, somehow this one is changing on me, by itself. Maybe it will only happen once in a blue moon but I will be checking it from now on.
      • KevinMc
        • 305
        So you're setting it down from it's highest setting and it's returning to the default of 3?
        What are you changing it to?
        KMc Designs
          Originally on the work bench with the subdriver out of the submarine the stern planes would go crazy at any sensitivity setting when running the motors. So I put it up front with the battery and it worked well. I put it in the sub and reset it to setting number 1, the least sensitivity setting and had a perfect run. Perfect periscope depth keeping all the way up to and including Full speed. The next time that I tried it about two weeks later it was all over the place , up and down and sideways. When I pulled it out of the water and ran the motors the stern planes were going crazy when I ran the motors. I took it back to my shop and reviewed again the instructions and cycled thru the set button and discovered that somehow it was back up to setting three again. I reset it back down to setting one and , on the bench, out of the water it so far looks good. Why, I dont know.
            • 1992
            Wanted to re-kindle this topic as I'm in the middle of a THOR Seawolf build using a Meriman SubDriver, ADF-2 and Lipo-Guard unit. I'm sure I've licked this before but can't remember back that far. Like the poster above, I get jittering on the rear planes (ADF controlled) when operating multiple servos at once, and a crazy dance when the drive is engaged. Is the solution a reduction in the sensitivity setting? or does the unit need to be relocated away from other electronics?
              • 13710
              That's normal -- the ADF pitch sensor responding to the mechanical motion its subjected to from the other devices. The net motion of the stern plane servo will be the desired angular displacement as commanded from your transmitter and the vector sum of the corrective signal sent from the ADF. Live with it. I and everyone else does.
                • 1992
                LOL... Dave, I'm a pretty educated guy and I STILL needed to read that twice. I'm gonna reduce sensitivity anyway, just to **** you off.
                  • 13710
                  Argh!......
                  Hell, you might be right. Let us know what happens.
                  • KevinMc
                    • 305
                    The short answer is "what HWSNBN said". :)
                    Bear in mind that you'll see more vibration induced noise on the bench than you will in the water, the water reduces your motor's max RPM and tends to damp things out a little.
                    KMc Designs
