Assembling the Merriman 2.5" Standard WTC
  • roedj
    • 564
    I have acquired a 2.5" Standard WTC from Caswell to replace the 3" WTC which came with a 2nd hand 1/96 Skipjack. Problem is ... is that I can't find any clear instructions on how to assemble it. I can look at the old 3" model and figure out where some of the parts go but not all. I have downloaded the instructions for the 3.5 WTC and while it gives some help it just doesn't go into enough detail for a total newb like me. I have also looked at a Merriman narrated video but again just not enough detail.
    So I figured why not just post it here and get help from any and all.
    First up is pix of the old and new WTC...
Name:	001 comparing the old 3 inch WTC with new 2point5 inch Standard WTC.jpg
    As we can see the new 2.5" one is just about 1/2" longer...
Name:	002 lining up the prop collars.jpg
ID:	100049... measuring the difference ...Click image for larger version
Name:	003 2point5 inch is one-half inch longer then old 3 inch WTC.jpg
    Ordinarily this would be no big thing except in my case the original builder of the Skipjack cemented some foam in the nose which blocks the 2.5" WTC...
Name:	004 foam block in nose of hull.jpg
ID:	100051... I'll have to find a way to fix this.
    Comparing the two motor end caps...Click image for larger version
Name:	005 comparing the two motor end caps.jpg
    and battery end caps...Click image for larger version
Name:	006 comparing the two battery end caps.jpg
    The ballast servo was out of alignment, I think...Click image for larger version
Name:	007a ballst servo - as received.jpg
    I'm hoping I didn't just screw up some critical alignment by straightening it out...Click image for larger version
Name:	007b ballast servo - straightened out.jpg
    This is an overall pic of all the parts received. By looking at the old 3" WTC I can identify some of them but there appears to be several changes that I'll need help identifying them all...
Name:	008 parts as received.jpg
    End of first post.
    Dan
  • roedj
    • 564
    Individual parts
    pictures of individual parts:
    motor bulkhead - dry side...Click image for larger version
Name:	009a motor bulkhead + motor.jpg
ID:	58828 and wet side...Click image for larger version
Name:	009b motor bulkhead wet side.jpg
    cylinder...Click image for larger version
Name:	010a Lexan Sub Driver cylinder.jpg
ID:	58830 and a mystery hole in the cylinder...Click image for larger version
Name:	010b mystery hole in cylinder.jpg
    the gas saver...Click image for larger version
Name:	011 gas saver.jpg
    "O" rings for ballast tank bulkheads...Click image for larger version
Name:	012 O rings for ballast bulkheads.jpg
    the ballast tank...Click image for larger version
Name:	013 ballast tank.jpg
    push rods to connect servos to control surfaces...Click image for larger version
Name:	014 push rods.jpg
    supplied wire for motor and ESC...Click image for larger version
Name:	015 supplied wire for motor.jpg
    ballast servo bulkhead - dry side...Click image for larger version
Name:	016a ballast servo bulkhead - dry side.jpg
ID:	58837 and wet side...Click image for larger version
Name:	016b ballast servo bulkhead - wet side.jpg
    forward ballast bulkhead - wet side...Click image for larger version
Name:	017a forward ballast bulkhead - wet side.jpg
ID:	58839 and dry side...Click image for larger version
Name:	017b forward ballast bulkhead - dry (battery) side.jpg
    battery bulkhead - dry side...Click image for larger version
Name:	018a battery bulkead - dry side.jpg
ID:	58841 and wet side...Click image for larger version
Name:	018b battery bulkhead - wet side.jpg
    air release valve -bottom...Click image for larger version
Name:	019a air release valve (bottom).jpg
ID:	58843 and top...Click image for larger version
Name:	019b air release valve (top).jpg
ID:	58844 and the valve placed in its location on the cylinder...Click image for larger version
Name:	019c air release valve placed on cylinder.jpg
    pin used as fulcrum for gas saver...Click image for larger version
Name:	020a pin used as fulcrum for gas saver.jpg
ID:	58846 and in the gas saver...Click image for larger version
Name:	020b pin mounted in gas saver.jpg
    Kli-Cons...Click image for larger version
Name:	021 three sets of D&E Kli-Cons.jpg
ID:	58848 three sets are supplied.
    extra servo mounting strap and extra hose...Click image for larger version
Name:	022 extra servo mounting strap + extra hose.jpg
    adapter for Propel can...Click image for larger version
Name:	023 adaptor for Proplel can.jpg
    SNORT manifold...Click image for larger version
Name:	024a SNORT manifold.jpg
ID:	58851 mounted part way on motor bulkhead...Click image for larger version
Name:	024b SNORT manifold mounted on motor bulkhead.jpg
    coupling to connect two push rods in different axes...Click image for larger version
Name:	025 coupling to tie two pushrods together.jpg
    coupling to tie two push rods together in same axis...Click image for larger version
Name:	026 coupling to tie two pushrodes together in same axis.jpg
    unknown manifold although curvature suggests it should mount on outside of cylinder...Click image for larger version
Name:	028 mystery manifold.jpg
    complete unknown...Click image for larger version
Name:	027 unknown 001.jpg
    plus screws (various sizes) extra socket screws, longer rod for gas saver(?).
    That's the parts. Right now I have to say that the assembly order baffles me. I can see where the parts go based on my old 3" Sub Driver, but the assembly order is critical, I think.
    Dan
    • roedj
      • 564
      No longer a mystery manifold
      I think I've figured out one of the manifolds.
      This one...Click image for larger version
ID:	58860 can be used to route SNORT air into the ballast tank as well as direct air from the sail back to the other SNORT manifold...Click image for larger version
ID:	58861 mounted at the rear of the motor bulkhead.
      There's still that mystery hole on the bottom of the cylinder. Could this be the hole to mount this other manifold? I don't know as I'd rather mount this manifold on the top of the cylinder, I think.
      I'm still working out the assembly order. I think I may have it - it ain't pretty but it should work.
      Big problem now is trying to figure out how to mount the ESC, Li-Po guard, angle keeper, two servos, the receiver, the small SNORT pump and God knows what else on the miserably small supplied frame that's attached to the motor bulkhead.
      I realize that Caswell and DM think this new 2.5" Sub Driver is really cool (lower CG, smaller parts and all that) but there's something to be said for lots of interior volume.
      Dan
      • roedj
        • 564
        Reading the documentation - what a concept!
        OK, flying in the face of my normal attitude that reading the documentation is for wussies, I actually located a contents list for this SD.
        Turns out that the extra servo strap identified here...Click image for larger version
ID:	58862 is in reality, and I'm quoting now, an on-board bottle restraining strap as demonstrated here...Click image for larger version
Name:	022b on-board bottle restraining strap.jpg
ID:	58863 and here(shown not secured to the cylinder)...Click image for larger version
Name:	022c on-board bottle restraining strap.jpg
ID:	58864...This also clears up the little puzzle of the mystery holes. They're for the strap..well duh.
        The only item on the list of contents not accounted for is the -- switch cable strain relief block so I guess that that's what this is...Click image for larger version
ID:	58865. Yeah, whatever.
        Also the part I identified as a coupling for two push rods...Click image for larger version
ID:	58866 may, in fact, be a ---spare push rod watertight seal.
        Now for the ESC's. I purchased a Mtroniks viper sub 10 ESC...Click image for larger version
Name:	029b Mtroniks viper sub10 ESC.jpg
ID:	58867 and I'm sure that this is just a wonderful ESC. Trouble is, is that this sucker is just too big for the equipment tray for this SD especially given all the other #@%%$@ I have to install. I know Mtroniks makes a smaller version of this ESC called a Viper micro 10...Click image for larger version
Name:	029a Mtroniks Viper micro 10 ESC.jpg
ID:	58868 which I have in another sub. It's much smaller. I've got to find this ESC. I'll try Caswell first.
        Dan
          Originally posted by roedj
          I know Mtroniks makes a smaller version of this ESC called a Viper micro 10...[ATTACH=CONFIG]4351[/ATTACH] which I have in another sub. It's much smaller. I've got to find this ESC. I'll try Caswell first.
          Dan
          See the web page for Mtroniks
          Look for the Micro or the Nano. Same thing, except the Nano has no epoxy or wires, making it smaller.
          • roedj
            • 564
            Mike,
            Thanks for the lead.
            In truth, I had already figured out that Caswell sold the ESC I needed. I was just wondering if anybody from the Caswell Empire was following this thread and watching me thrash about trying to figure this thing out. I figure I'd chum the waters a bit with the ," I'll try Caswell first," comment. Didn't take long for the fish to rise to the bait, LOL.
            Dan
              Mike,
              Dan
              "We only eat really distressed bait! You can suffer a bit more!" He says, spitting out the minnow!
              • roedj
                • 564
                Now I'm distessed bait
                Someone,
                Can someone confirm for me that this round black "thing" in the hole in the ballast tank bulkhead is, in fact, an "O" ring?...Click image for larger version
Name:	030 O ring in ballast bulkhead.jpg
ID:	58869 It sure looks like one to me but who knows?
                I'm asking because I'm wondering if I need to use some sort of RTV sealant for the brass interconnecting tube or can I just rely on the "O" rings to keep the water out.
                Dan
                  • 13967
                  Nooooo! ...
                  The Nano is only for the boats witha 1.25" SD!
                    • 13967
                    Someone,
                    Can someone confirm for me that this round black "thing" in the hole in the ballast tank bulkhead is, in fact, an "O" ring?...[ATTACH=CONFIG]4352[/ATTACH] It sure looks like one to me but who knows?
                    Dan
                    Dan,
                    Yes, both ballast bulkheads have this O-ring which effects the seal between bulkhead and conduit tube. The conduit tube is greased, not RTV'ed when slipped into the ballast tank space. It's the last item to 'slip' into place during assembly.
                    The strain-relief block glues to the inside face of the forward bulkhead and is drilled to pass the three wires between battery pack plug and mission switch -- it unloads the switch solder joints from any flexing as a consequence of battery handling.
                    • roedj
                      • 564
                      Originally posted by Merriman
                      Dan,
                      Which three wires? I can see switching one of the battery leads (+ or -) to effect an on/off condition but I don't get the three wires comment. Please explain.
                      BTW, good to have you back. I take it your presence here means thing are improving on the home front.
                      Dan
                      • roedj
                        • 564
                        Greasing the "O" rings
                        What kind of grease do you use? Can I use this same grease to apply to the "O" rings to make it easier to slide the two ballast bulkheads into the cylinder?
                        Also, I see where Caswell sells a waterproof switch, P/N BHWS, which is rated for 250V @ 2 amps. Do you recommend this switch to be used to turn the system on and off? I'm a little concerned because I think the current draw could be occasionally as much as 5 amps or more with all the electronics and the motor sucking current. I see a depression molded into the dry side of the forward end cap. Is this where you would install the switch? I'll also glue the strain relief block nearby too.
                        I've made up a wooden tool to aid in the installation process. I'll show a picture later.
                        Dan
                        • roedj
                          • 564
                          bulkhead tool + velcro
                          I've decide to use Velcro brand products to attach the various components to the equipment frame on the motor bulkhead ...Click image for larger version
Name:	032 Velco thin profile.jpg
ID:	58877... more on this later.
                          I've purchased the purest silicone grease I can find to lubricate the "O" rings...Click image for larger version
Name:	031 McNett silicone grease.jpg
ID:	58878...It's available in a lot of SCUBA dive shops.
                          The assembly procedure for the SD ballast tank has at least one "tricky" part which, hopefully, won't be so "tricky" in the end. It's the part where we attach the gas line to the gas bottle. I'm sure DM has worked this out long ago but I see only one way to do it. The problem is that I cannot turn the gas bottle inside the cylinder...Click image for larger version
Name:	033 cannot turn gas bottle in cylinder.jpg
ID:	58884...it's just too bloody long. This means, I think, that the gas line must be attached externally to the cylinder and the only way to do this is to physically bring the gas line outside of the cylinder like this...Click image for larger version
Name:	034 attach gas line to bottle.jpg
ID:	58879...I had to push the bulkhead forward of its normal position to get enough of the gas line outside of the cylinder. I also did not push the bulkhead so far forward that the "O" ring would be over the ballast tank hole for fear of nicking the ring. Note that for this demo I did not have the hose compression collar on the tube nor did I have the "O" ring installed on the bulkhead.
                          I've made up a tool...Click image for larger version
Name:	035a bulkhead adjustment tool.jpg
ID:	58880... to move the bulkheads around inside the cylinder. It's two pieces of 1/2" by 3/8" basswood glued to a piece of 1" by 3" milled pine. It just fits in the cylinder. With this tool I can push the bulkheads in and out of the cylinder...Click image for larger version
Name:	035b tool used to push on bulkhead.jpg
ID:	58881... because the tool is longer than the cylinder...Click image for larger version
Name:	035c tool is longer than cylinder.jpg
ID:	58882... It can get around the gas bottle if need to be adjust a bulkhead...Click image for larger version
Name:	035d H in tool used to get around the gas bottle.jpg
                          Later, I'll show the actual assembly of the ballast tank.
                          Dan
                          Last edited by roedj; 06-27-2010, 09:07 AM. Reason: clarified picture of bottle in hole
                          • roedj
                            • 564
                            Preparing the on-board bottle cylinder hole
                            With some behind the scenes advice from DM I've decided to enlarge the cylinder hole where the on-board bottle is placed.
                            First I sanded and filed the hole...Click image for larger version
Name:	036a enlarging the on-board bottle cylinder hole.jpg
ID:	58887...the hole now looks oblong like this...Click image for larger version
Name:	036b the enlarged hole.jpg
ID:	58888... God, I hate the effects of digital photography. Every little scratch and oops really shows up.
                            "What did you use to make the hole bigger, klutz, a jackhammer?"
                            Anyway, I did it to allow me to turn the bottle inside the cylinder for the ballast tank assembly like this...Click image for larger version
Name:	037a start the bottle thru the hole.jpg
ID:	58889...then this...Click image for larger version
Name:	037b bottle started in the hole.jpg
ID:	58890,,, and finally this...Click image for larger version
Name:	037c bottle in the hole.jpg
                            I also had to deepen the "O" ring channel just a tad to allow me to actually get the bulkhead in the cylinder, like this...Click image for larger version
Name:	038 deepening the O ring channel.jpg
ID:	58892... be sure to use a nice sharp rat tail file and go slowly as a little filing goes a long way when you're only trying to remove a fraction of a millimeter.
                            Dan
                            • roedj
                              • 564
                              correcting a color cast in the photos
                              I really don't know if anyone cares about this but I do so here goes. You may have noticed that I try and include a piece of white in most of my photos. That's not accidental. I do it to allow me to correct the green color cast caused by the fluorescent lights over my work station. I'm using Adobe Photoshop Elements 4. It's in the Enhanced menu under Color.
                              Here's the before...Click image for larger version
Name:	038 extra showing uncorrected color cast.jpg
ID:	58893... and here's the color corrected version...Click image for larger version
                              This is undoubtedly more important in nature and people photos but what the hell...
                              Dan
