Announcement
Forum rules and expectations
See more
See less
D&E Skipjack Trim
  • Filter
  • #31
    Originally posted by llangston1 View Post
    Its been a while since my last post on my Skipjack. Haven’t had much time to work on it. But yesterday I finally had a chance to get ii in a large pool to check it out. I only got one video of it during surface ops. It ran good but still a little bow low and leaning to the left. I can’t keep the battery pack from sliding over on the left side die to the wires running through the connecting tube to the engine compartment. Even though in the bathtub I had it trimmed so the sail was just above the surface in the pool it dove quickly to the bottom. I don't have the auto leveler in the system and it was next to impossible to keep the boat level in submerged ops. I also think I might have been losing signal when near the bottom (shallow end). I am having trouble keeping the Control fins firmly attached to the hinge rods. While they appear attached in the air when in the water a control input might or might not cause the plane to move. It was really noticeable in the rudders where the upper rudder would move but the lower one would not. I haven’t CA’s the fins to the hinge pins so I can tweak their alignment after getting everything installed. But apparently they have gotten looser now so water pressure jist pushes them streamlined. That can cause some weird motions in the water for sure. The sub did have a good bit of roll during turns. The ballast controls seemed to work fine. It never failed to surface but trying to hold decks awash or periscope depths was impossible. I will post the one video I have when I get it uploaded to youtube.
    A submerged boat, without an angle-keeper, is all but impossible to drive in pitch, so get that angle-keeper in there!
    Put flats on the control surface operating shafts where the yoke set-screw intersects the shaft. Are you sure that the operating shafts are not loose within the bores of the control surfaces? Check!
ID:	142134Click image for larger version
ID:	142135Click image for larger version
    Keep at it, pal.
    "... well, that takes care of Jorgenson's theory!"
    • #32
      Here is the video of the open sea trials from yesterday.
      https://youtu.be/_1V6KmYGiB4
      • #33
        Yes I believe you are correct that the surfaces are loose on the shafts. I never tried to CA them together so I could fine tune the surface positions after tightening down the control yokes. Apparently some have loosened to the point that they will no longer hold against water pressure.
        • #34
          A simple fix. Get to it.
          • #35
            So would you CA the planes to the brass rod hinges or is there some other adhesive that would stiffen up the connection but still allow for fine adjustment of the planes if misaligned between each other. My sub’s hull doesn’t come apart at the rear so I dont have full access to the yokes. Everything is tucked up inside the rear cone and it is extremely difficult to both line up planes and tighten the yoke screws with only 2 hands. It’s not impossible but very difficult and usually by the time the yokes are tight the planes have slipped a little and need to be trued to each other.
