Greetings!
For years i have been using racing packs in dry compartments for power supply and am now about to use an SLA battery in the wet. I made custom watertight powerconnections, however as i plan to use the cells on multiple models i'd rather install some prefab/stock plugs. I have often seen XT60's beeing used with e.g. silicon grease for waterproofing. Wonder if there is a less messy way.
How do you waterproof your connectors?
Jörg
Jörg
