3D Printed Utility Boat
    Et tu, Brute?....
    No betrayal. I like targets too.
    Originally posted by Das Boot
    How much you want for it?
    Sorry! I glued it up and gave it to our Grandson!
    Et tu, Brute?....
    "SPECIAL NOTE"
    I am closing out this Utility Boat build! Just can't get into it! I want to thank all those that did contribute to my build!!! It's Submarines for me!! Another lesson learned! At pushing 80, it sure seems I am still learning a lot about what not to do!! :-))
    "SPECIAL NOTE"
    The main parts of the wheelhouse are complete.
ID:	156673Click image for larger version
Name:	Wheel house 3.jpg
    I will be adding some detailed items on the top of the house, as well as a helm interior unit (working on a design)
    I have been working on a new super-structure and wheelhouse for the Utility Boat.
ID:	156660Click image for larger version
Name:	Wheelhouse decking 1.jpg
ID:	156662Click image for larger version
Name:	Wheelhouse decking.jpg
    I have been using TinkerCad, and re-designing other Thingiverse Tug Boat wheelhouses for my boat. The last photo is a simulated wood deck material I will use on top of the actual decking that you see in the 1st bottom photo.
    Nice looking gunboat.
    You only need full access to the hull when installing the running gear and electronics. After that you only need to access it to charge or swap out batteries. Having the entire deck removable lends to water getting into the hull through the gap. You could semi-permanently bond the deck to the hull using RTV silicone. A small access port with raised edges under the superstructure for accessing the battery.
    Not my first boat, and I totally understand what you are saying.
    As I get further into the build, I will certainly take everything into consideration. None of my submarines or surface boats go any further than my swimming pool (no waves nor white caps) and most of the time it is only one time just to make sure they work, and then its's onto the shelf. As I have stated before, health issues keep me home bound! Thank you for your input!
    The 3D files for the Utility Boat I am building did not come out all! And what you see below is my cardboard deck pattern.
    Click image for larger version  Name:	Deck Pattern.jpg Views:	0 Size:	48.3 KB ID:	156593Click image for larger version  Name:	Deck Top.jpg Views:	0 Size:	47.3 KB ID:	156594
    The design of the deck itself did not fit the hull structure, and also the superstructure was way off as to size and design. So needless to say, I will go to scratch building the deck and the superstructure on this boat.
    Currently my printer is fabricating the 3 deck plate sections required to build a solid piece deck. The superstructure will be mounted permanently to the deck, and the deck and superstructure will be removeable as a one piece unit to gain access to the hull interior. This will be a much better design for sure!
    What powerplant are you putting in?
    Not sure on the powerplant as of yet, but most likely in the 550 series brushed motor!
    Now that the main hull is completed, I am starting on the deck parts.
ID:	156531Click image for larger version
Name:	Bow Deck 2.jpg
    The bow deck section will need some sanding and fitting work. May need to do some re-design work on the decking sections.
    A little tough holding it together at this point. Not glued up as of yet! The boat is 21.50" long with a 5.25" beam at the widest point.
