Bubbles from blow hole.
  • pjdog
    • 302
    Gas continues to bubble out of the vent valve when the transmitter stick is in
    neutral. What would be your best guess as to the problem.
    1. Adjust the position of the two wheel-collars on the servo pushrod. Moving the
    wheel-collars moving the wheel-collars aft to provide less vent and more blow.
    2. Loosen the blow valve setscrew. Moving the blow valve aft to retard blow valve actuation.
    Jack
    • 12382
    Jack
    Put a drop of oil on the vent valve rubber element. Test. If the vent still leaks, go on to step-1 above. If it still leaks, move on to step-2 and move the wheel-collars aft a bit more.
    If the above fail, take a big hammer to it.
    • pjdog
      • 302
      bubbles
      Got it, Step 3, the ol' Ford wrench.
      • pjdog
        • 302
        bubbles
        Little drop of oil worked. Save me messing with wheel collers.
        I'll keep that in mind for when I get my Gato S/D.
        Thanks for the help.
        Jack
          • 12382
          Jack
          Good man.
          First rule of trouble-shooting: do the easy stuff first.
          Smart trouble-shooter: when he hears hoof beats in the distance he thinks, 'horse'.
          Stupid trouble-shooter: when he hears hoof beats in the distance he thinks, 'zebra'.
          • pjdog
            • 302
            bubbles
            It's always been my belief to ask for help if it's available. Never suffer in silence. If no help comes do the best you can a little at a time. No big adjustments. Lots of little ones until you prevail.
            • shamrock
              • Jan 2009
              • 69
              wet boat
              good man pj sounds like you are getting your boat wet.just like me spent years makeing targets .now whole new ballgame good luck trying to drive in three dimentions
              horse power by the hour
              • plastic66
                • Jun 2009
                • 29
                Good for you PJ, asking questions is the way to go here. I am learning that as I am working on my Seaview. I had a problem with a part not fitting, so intead of asking what to do, I tried to fix it myself. Outcome: disaster, I messed with so much that I nearly ruined it.
                So I took a step back, gave it break, and went back and situation resolved. Next time, I am asking.
                • pjdog
                  • 302
                  wet u522
                  Kirt:
                  Yep, been getting the U552 type VII wet all day. Trimming a sub is allot of work. First it was bow high, then dove bow first and heavy, then the bow dove high? I think this will take time. Lots of trial and error. The snort works great, the ballast blow works great, the ADF worked but had allot of trouble getting it in the dry space. So I work that later. Had to make longer drive shaft couplers. Can't find a small enough water tight on/off switch in my one stop light town. But I'm going to hang in there. Had to mess with the rudders all day. That's a mess but I may have it. Wish D. Merrinam would get the fittings kit for the type VII, they are late. It's late now but I'll post a picture of the second days dives.
                  Tomorrow is my wife's birthday? 65 years young. What do you thing about getting her a type XXI with all the Caswell/Merriman needed components? Or should I go with a fancy dinner and flowers?
                  Jack
                    • 12382
                    You'll spring for the flowers and dinner only if you have a will to live.
                    Congratulations. And many more for you and the bride.
                    And get off my back with the Type-7 work ... I'm dancing as fast as I can.
                      • 2848
                      Kirt:
                      Jack
                      You're not sure it's her birthday? You post her age on a sub forum? You want to buy her a model rather than dinner and flowers?
                      Well, it was nice knowing you. I'll guess your demise will be scissors in the chest, I'll put $20 on that.
                      • pjdog
                        • 302
                        Flowers & dinner
                        Knowing that David is the RC sub god and all knowing, I'm going with the dinner and flowers.
                        Thanks for the help david.
                        All the fittings kit remarks are just little nudges. Your doing great.
                        jack
                          • 12382
                          jack
                          We just saved your life, pal!
                          • shamrock
                            • Jan 2009
                            • 69
                            glad to see you're still alive
                            pj,sorry for late reply had to go offshore gulf of mexico waits for no man.hope the wifes birthday went without a htch,see you're still alive so it must have.how's the running of the vii going?see you started on the gato.looking nice.i am jelous you have 2 subs and i only have one.working on saving money for my vii.maybe i will buy my wife one for her birthday.installed snort system in my gato.tested it in the neighbor's kiddie pool.will try real test this weekend if work will leave me alone.
                            • pjdog
                              • 302
                              Type VII
                              Shamrock:
                              Pray that work keeps bothering you. Lot's of Americans are with out it. Can't tell you how many of my younger friends are looking for work.
                              Finally got the type VII balanced. Was looking at the 5 dvd's on the Gato. The last dvd (5) had a blurb on how to balance at the snorkel level. It was easy when you have a idea what you are to do. The dvd's are so helpful.
                              Jack
