Hooking up Twin Drive Motors to a Single ESC
    How do you hook up the motors and ESC in the Gato and Type VII, In series or parallel?
    • 13982
    Parallel.
      Thanks. What's the rationale for going parallel,( excluding the fact that if connected in series 1 motor burns out the circuit will be broken)?
        • 13982
        compound wound motors, when hooked up in parallel will not run evenly -- the 'weaker' motor will shunt its current to the 'stronger' motor.
