need help
  • KURT250
    • Jul 2012
    • 19
    need help
    i new to r.c. subs. i have a d&e wtc for the gas ballast system . this type goes into the revell 1/72 type 7 u-boat. what i need now is a basic diagram of the wiring lay out for the type 7 with out forward dive planes or torpedo tubes. i also need a list of the electronics needed, and the basic lay out of the componets is this printed up some where , or can it be supplied by some one. thanks for any help.kurt250
    • 3752
    Kurt250,
    Welcome!
    There is a lot of resource at this site and others, but mainly here. One stop would be here http://support.caswellplating.com/in...-cabal-reports These cabal reports will give you insight on setting up your sub. The builders thread and the contests threads also have plenty of information for the type VII, but if you read the other build logs you will see some similarities in all the subs (like receiver, pitch controller [leveler], failsafe, esc [electronic speed control], servos, battery [LiPo], dog bone connector, and assorted bits of brass)
    We are all here to help, from beginners like me to old timers like David.
    tom
      • 13975
      Old!!!!!!!............???????????????
      [ATTACH=CONFIG]17950[/ATTACH][ATTACH=CONFIG]17951[/ATTACH][ATTACH=CONFIG]17952[/ATTACH][ATTACH=CONFIG]17953[/ATTACH][ATTACH=CONFIG]17954[/ATTACH][ATTACH=CONFIG]17955[/ATTACH][ATTACH=CONFIG]17956[/ATTACH][ATTACH=CONFIG]17957[/ATTACH][ATTACH=CONFIG]17958[/ATTACH][ATTACH=CONFIG]17959[/ATTACH]
        • 3752
        And celebrating another year older in a few days.
          • 13975
          (you're not helping!)
            Forgive me if I'm wrong, but shouldn't the fuse be in the main line to cut all power from everything, not just the motor?
            And shouldn't the mission switch be on the positive side of the battery?
              • 2639
              Yes to the fuse. Some people advocate fitting a fuse either side of the controller, I think that is overkill. Position of switch doesn't really matter in this instance.
                • 3752
                Subculture, I went to modify the picture and you posted the answer.
                Here is a corrected photo.
                  • 13975
                  Agreed. Thanks for putting that right, Tom.
                  • Scott T
                    • May 2009
                    • 414
                    Everybody sure about this one? I thought the currents flow in DC was from the (-) negative
                    too the Positive (+). So shouldn't the fuse be in the negative lead? Otherwise the current
                    flows through all the componets before it hits the fuse.
                    Scott T
                      • 13975
                      Does not matter which side of the poles you put the fuse. Current flow is speed of light (a bit less, but let's not get too anal here), break the circuit, EMF goes to zero and current flow stops dead.
                      • KURT250
                        • Jul 2012
                        • 19
                        thanks to you all. this was very helpful. but im afraid in need a little more, i need the names of the various electronic parts, what is the lpb switch?, the lipo guard?, the esc + bec? i know you guys do this all the time so forgive me for being a dummy in these issues. i'll learn ,its just going to take me a wile. thanks again to you all, and please bear with me. kurt250
                          Just look at the electronics kits, as they show all these parts.
                          • satlite440
                            • Jul 2012
                            • 177
ID:	75477Click image for larger version
ID:	75478Click image for larger version
ID:	75479i think what he wants is something like this i am building a vIIc uboat.i got
                            1 2inch revell vIIc subdriver with 4 servos/2 moters/ microviper10 installed
                            2 radio sys 6 or 8 ch
                            3 rx sombra labs (lepton6 or sl8) if you get the 6 you need a different mini crystal ordered seperatly
                            4 2 batt's&charger
                            5 the adf2 for stern planes&failsafe
                            6 lipogard failsafe
                            7 mini snort system kit (moter&control board)
                            8 propel
                            9 the will to fit it all together
                              • 3752
                              Esc - electronic speed controller allows you to increase, decrease, or reverse your motor speed (ultimately your props)
                              bec - battery elimination circuit allows you to use one power supply and take from that a 5 volt line to your receiver
                              lpb - low pressure blower is simply a pump to suck air in and displace water in your ballast tank so the switch turns on or off the pump.
                              lipo guard - a device to notify you of a potential low voltage in you LiPo battery. Bad stuff happens when LiPo batteries go too low.
