Follow David's advice one boat at a time.
The Type 7 WTC will give you a good lesson in learning the ways of a new SD.
Short answer is nothing. I think after operating that way every other weekend of summer for a decade, I pretty much covered every conceivable option in terms of waterproofing connections. Here is the "best" way I came up with - "best' means less likely to ingress water. IT therefore remains INFERIOR IME to the longevity of a new SD with no external power connections. Yes a new SD is a substantial investment - but the key word there is INVESTMENT. Its folly to save a couple of bucks on a system that is prone to break down. The questionable longevity of so-called waterproofed connections will cost you time and money.
Here is the "best' approach I have come up with. - But again I don't recommend this over parking a lower weight higher capacity battery in the forward end of the SD. The ALFA turns best when the boat is set up nice and light.
Battery preparations
The white ring is styrene - fill this with RTV silicon
Charging wires that fit the females from the battery. The same male brass lugs penetrate through the WTC end cap. (See my diagram above)
