Need Help Identifying New Kit!
  • SubSteve
    • Apr 2022
    • 129
    I'm curious where the nice looking step-sail came from!
      • 2536
      Perhaps it came with the kit, Dave mentioned likely to be a scale shipyard hull, or ‘shock horror’ someone scratch built it. :)
        • 3547
        Is Dave Manley still around?
          • 2536
          Yeah, looks as if he's living in the woods like a bear!
            • 2536
            Originally posted by button pusher
            I am worried about the stuffing boxes though, anyone know what grease is recommended? Doesn't look like mine are fully stuffed.
            If the seals are nitrile use silicone grease, you shouldn't need to fill shafts up with grease, you only need to grease the rubber gland . I can't recall what seals were used on these modules, someone might chip in, they will likely be either o-rings or lip seals of some kind.
            If silicone o-rings are used then use a ptfe grease, as silicone grease tends to make them swell up.
              • 3547
              Too bad Small World Models folded.
              I like Dave Manley's rotary type servo output seals.
              He had a 2" cylinder with tandem servos in development for the Type VII but decided to kill it.
                • 2536
                You can use any glanded o-ring (available from Norbert Bruggen) or a lip seal as a rotary seal, even bellows work as a rotary seal- Graupner used them like that on the Shark kit. Also simple lengths of silicone tubing work well to seal rotary shafts.
                This is really the best way to seal control shafts from a WTC as it puts least strain on the seal and the servo.
                  • 3684
                  Dave used cup seals for drive shaft and o-rings for servos
