So I bought some STL files… What now?
  • Starfarer42
    • Mar 2026
    • 1
    As a Canadian, there is a special place in my heart for the Victoria/Upholder class submarine so I decided to purchase the STL files package from Nautilus Drydocks. I expected there would be some kind of README file with more information included in the download, but it’s just STL files. This is both my first submarine and my first 3D printing project so I’m a bit at a loss about what to do next.
    I have a number of questions I hope someone here can answer:
    1. ​​​​How do I know what size of shaft I should order for the rudder/dive plane linkages? Is there a good way to measure the holes in the model? (The software I’ve got is making it hard to measure directly across the hole, as opposed to diagonally to some point deeper inside.)
    2. I’d like to include some bushings to make the linkages friction-free. Do I need to edit the STL file to add the appropriate sized holder for my particular bushings?
    3. The product page recommends the 70mm WTC, but should I order it with the two extra servos for the forward dive planes? I really only need one servo since I won’t be implementing any kind of retraction mechanism.
      1. If I did order the WTC with the two extra servos, would they be in the forward compartment or in the back with the other electronics?
    As built the Upholder/Victoria class was designed as a replacement for the Oberon class for use as hunter-killer and training subs. The submarines, which have a single-skinned, teardrop-shaped hull, displace 2,220 long tons (2,260 t) surfaced and 2,455 long tons (2,494 t) submerged. They are 230 feet 7 inches (70.3 m) long overall with a beam of 25 feet 0 inches (7.6 m) and a draught of 17 feet 8 inches (5.4 m). This file set was created by Randy Sanders and is the first one he has created that incorporates the amazingly intricate anechoic tiling details that really make this hull stand out in terms of realism. The Upholder/Victoria Class is actually a very strong performer as a scale submarine, with great turning performance and speed. The huge sail imparts a significant sail induced roll, for very cool banking turns at speed. Now includes periscope and mast tops in file set!Overall Length in supplied scale: 947.5mmOverall Beam in supplied scale: 100mmOverall Height with Sail: 220mmFilament required: 975cm3 (no supports included). Approximatley 1 full 1kg roll with no supports Distance between internal support ribs is approximatley 84mm. Our 70mm cylinder is a great fit for this boat.
  • Ed Kirk
    • Dec 2025
    • 81
    I use Orca slicer to "Add Part" or "Add Negative Part" to modify the STL file. Mostly trial and error because the actual print seems to print holes smaller then actual dimensions called for. I pick a spot on the part and Add Negative part in various sizes to get just the right size, it may take several practice prints to get the size you want. Lots of work and it takes small incremental changes. I use metric parts and print in metric.
    In the photo above you can see the negative part (a cylinder) shaded to get the hole size I want, in this case the hole size for brass tubing. The shaded hull section under the build plat is used as a template to locate holes for part fits between the two hull section which I bolt together rather then use glue.
    I also create parts using CAD to modify STL files by adding or using negative. Orca has a measurement tool but I haven't figured it out yet.
    I have been working on the Typhoon (a scaled down short version for fun sailing) for several months, I designed my own WTC in CAD and printed it.
    • CC Clarke
      • Aug 2020
      • 308
      Every modeler's toolbox should contain a set of inexpensive digital calipers. You can order them online or buy them at any auto parts shop. I keep a pair next to my computer when modeling from a physical part and another pair at my workbench to measure parts while building. I use one, (or both) nearly every day. I also use CAD software to verify measurements during the design phase.
      Usually, split hull files optimized for RC use are sequentially numbered and labeled as Top or Bottom, Upper or Lower. Print everything and lay it out. If it still seems confusing, write the part name on the interior with a Sharpie marker when you remove it from the printer. On the files I design, I label the part's ID and Rev number into each part to insure I'm holding the latest rev prior to bonding.
        • 1994
        Don't get caught up in the digital side of things.
        As CC said, mark the parts, assemble the parts, take stock and move forward. If you need a bigger hole, drill one out. If you don't know what size a hole is, measure it.
        As for the cylinder, extra servos are mounted in the front, so you'd get two forward and two rear.
        • CC Clarke
          • Aug 2020
          • 308
          I should have mentioned this earlier, but better late than never. Here's an invaluable resource to answer all of the basic questions every beginner has and get you started on the right track: Diving Deep - How to Build and Operate an RC Submarine PDF | Drydocks
          CC
            • 2536
            I would start with something a little more comprehensive, e.g. a full kit with instructions and a preconfigured dive module. Save the Upholder for a second or third build.
            By all means disregard this advice if you wish, but you may find yourself overwhelmed.
