Using existing separate deck vs waterline cut vs vertical hull cut.
Installing/Accessing the WTC in the Revell 1/72 Type VII
Make it simple, make strong, make it work!Tags: None -
i originally had just the deck removable, its easiest way, but found i was stretching the hull and breaking things everytime the cylinder went in out, thats me. Ive now made a waterline cut but still ned to clean up the joint
BTW this is Albion, ive lost my password and cant recover itComment
Hey Albion. How are you doing?i originally had just the deck removable, its easiest way, but found i was stretching the hull and breaking things everytime the cylinder went in out, thats me. Ive now made a waterline cut but still ned to clean up the joint
I'm relieved it's only your password you lost. Haven't heard from you so long I feared for the worst.Make it simple, make strong, make it work!Comment
im good, moved back to uk, so last few years (post covid) has been busy with moving, sorting new house out and genrally getting stuff sorted. Also had some other hobbies going on, but now being retired ive got time to get back into subs, ive even got a decent lake near me to use.
Albion, I can easily reset your password. I'd prefer we do that for you rather than beginning a new user.i originally had just the deck removable, its easiest way, but found i was stretching the hull and breaking things everytime the cylinder went in out, thats me. Ive now made a waterline cut but still ned to clean up the joint
