DOA Neptune SB1 Tiger Thunder Seawolf - need some help
[QUOTE=tifosi12;n182402]
No worries. I'm glad you answered and this thread didn't just end up in the usual echo chamber. And yes, batteries are usually the first culprit.
Tomorrow I'll have time to investigate more. I'm hoping to find that diode or something that inhibits the electricity. I might end up continuity checking every single soldering joint on that board. taught/QUOTE]
Here's an old trick a vacuum-tube guy taught me: (In those days, rubber gloves were your friend as there was a lot of high-voltage stuff in there). You energize the board/frame, grip its edges and twist it and bang it around and look for fluctuation in total current draw -- this would indicate cold solder joints as the Ampere meter spiked about.Leave a comment:
Tomorrow I'll have time to investigate more. I'm hoping to find that diode or something that inhibits the electricity. I might end up continuity checking every single soldering joint on that board. Odd.Leave a comment:
👍 1Leave a comment:
Good chance that there is such a thing since this board also has 2 connectors to directly charge the battery.Leave a comment:
Yes. In fact I did a little test: I connected the battery directly to the electronics in the center part of the ship thus bypassing the electronic board in the front with the on/off switch and things came to life (jittering servos etc, but that was probably down to the transmitter not operating). So something is stopping the flow of electricity in the front board.
Normally I would say that board is toast, lets replace it. But I have the exact problem on both ships, which makes me wonder whether I'm doing something wrong. I followed the manual and there is nothing else involved but throwing the on/off switch. So I am at a loss.
We have several Neptune SB1 captains on here, did any of you guys ever have a problem like that with your boats? RCSubGuy you had a few of these?
If I were to replace the front electronics board, do I need to have the voltage going to the center changed? Does that board act like a transformer converting the 12V to something smaller?
DavidLeave a comment:
If I were to replace the front electronics board, do I need to have the voltage going to the center changed? Does that board act like a transformer converting the 12V to something smaller?Last edited by tifosi12; 08-28-2024, 07:07 AM.Leave a comment:
Yes, brand new 12V.
But that's not my point: I'm stunned that zero voltage comes through the cables of the front electronics when the battery is attached and the switch is flipped.
And that's the case for both boats. So either both have a faulty front electronics board or I am missing something fundamental.Leave a comment:
Yes, brand new 12V.
A while ago I bought a Neptune SB-1 and it was of course a DOA. So I bought recently another Neptune SB-1, which claims to be in good condition but seems to be the same DOA.
I did replace the battery although in my latest purchase it still had a good 11.5V. Anyhow, when I switch either boat on, absolutely nothing happens. So I measured the voltage going through the electronics in the front towards the electronics in the middle. Basically just unplugged and measure at the plug and discovered that zero voltage is coming through. And that's the case with both boats.
So am I missing here something? I thought that all I had to do was turn the switch at the bottom (one is not used but just to be on the safe side I switched both) and there should be some voltage flowing?
Or is it possible that both of these power-on electronic boards in the front are toast? If so, do I care? Can I just wire the switch directly to the cable bypassing that board (which I believe is for charging the battery and powering the video camera)? Is there possibly a fuse involved that I don't know of?
Any help appreciated.Leave a comment:
Any help appreciated.Tags: None
