Brass sheet thickness for control arms
    • 3666
    When making control arms out of brass sheet what's the thickness of the brass you usually use, 0.5mm, 0.8mm or 1mm?
    • 1038
    1mm. No sheet material but bars.
      • 13941
      .030"............................
        • 3666
        That would be 0.76 mm.
          • 13941
          No. That would be .030-of-an-inch, damnit!
            • 3666
            "Metric is simply a better system of units than imperial​."
              • 13941
              Show me one... just ONE ****ing r/c submarine you've built and operated using the Metric system of measurements?
                Also measured in fractions so it will be easyer to adopt then the metric system.
Name:	Banana for Scale.jpg
                Grtz,
                Bart
                  • 13941
                  Grtz,
                  Bart
                  ... and the thread plummits down a rocky ravine! No survivors.
                    • 2617
                      • 13941
                      ROFLMAO!!!!
                      Yup... the 'finishing move'. (Once again illustrating the superiority of the female anatomy!).
