Sintra in the wet
    • 3493
    Sintra in the wet
    Can Sintra PVC board withstand prolonged immersion in water?
    • 1984
    I've been using it for decades with no issues whatsoever. While technically a "foam" board, the central section is composed of very rigid closed cells. Unless you're planning dives to the deep, dark depths, you should have nothing to worry about.
