Fibreglassing a boat
  • hywel
    • Aug 2022
    • 65
    I tell ya, this whole submarine world is great as I’m running into problems I’ve never had before!
    Heres my latest: I’m building the Typhoon. Has lots of windows. I’m fibreglassing the inside as resin can be brittle. I figured I could just block the outside of the windows with tape, the resin would seep into the holes and I’d just wet n dry the outside. Trouble is the outside needs to be painted so now I have to block EVERY SINGLE WINDOW when I paint.
    Not happening!
    What’ve other folks done in this situation? I clearly can’t be the first here.
    cheers,
    - hywel
    • 1100
    Err... blocking every single window is what i'd do. Or paint first, add glass later.
    There is no 'easy' trick here, imo. You dont want empty holes but windows, You cut your proper tape templates ONCE, you install them carefully ONCE, you paint ONCE and be done with it.
    i usually file out the window and glue plexiglass into them.
    Jörg
    • hywel
      • Aug 2022
      • 65
      Thanks, figured there was no easy button for this but had to ask:)
      blocking it is!
        • 898
        I hope this can be an "easy button" for at least one step: https://www.rcgroups.com/forums/show...9&postcount=99
        • hywel
          • Aug 2022
          • 65
          Thank you, will check this out for sure!
            Hywel,
            I had a thought based on what you'd said. You're not thinking that all of the drain/limber holes in the hull are windows, are you? The only "windows" in the sub are in the sail, and there are only a handful of them. The rest of the hull openings are typically backed with a mesh.
            • hywel
              • Aug 2022
              • 65
              Aha! I thought the larger square holes at the bottom of the hull were the main water holes but of course what you say makes a lot more sense. Disaster averted!
              Back to Submarines 101 I go! Thank you, Bob!
