Batteries...and leaks
  • Thorbrandr
    • Mar 2022
    • 124
    Got a nice new 5000 m-A-h NiMH battery with a leak. some rust showing? Battery toast, or let dry out?
    Chris
    • 1152
    Trash it or get a refund. Don’t screw around with batteries.
    • SubICman
      • Jun 2022
      • 87
      Got a picture of it?
      • Thorbrandr
        • Mar 2022
        • 124
        Not handy. There is a 3/32" hole between cells. Rusty water came dripping out. I can reseal it in a water tight shrink tube, but don't trust rusty contacts. I had it on the charger before I saw the water condensation - it is hard to see when installed in the sub - the charger could only get to 14V, not the 15V or so when new.
        A few of the cells have rust on the ends.
        Chris
          • 330
          Dont screw around with faulty batteries. You could have a fire too, either in the shop charging or burn up your boat discharging.
          Or your boat simply loosing power and you have now a 'Thresher' to swim for. Don't be penny wise and pound foolish.
          Return it and get a refund or exchnage. Crappy battery.
            • 1152
            Didn’t Mike Dory have a boat explode in his garage years ago?
            • wlambing
              • Nov 2020
              • 295
              Mike's explosion was from a sealed lead-acid battery. Was charging it in the boat and had a very bad H2 build-up inside the watertight box, in hull. Impressive destruction!!!
