source for smaller diameter longer bellows
  • Thorbrandr
    • Mar 2022
    • 153
    Have been looking...probably not in the right spots. Where can I find some like the ones used by OTW? Along with the brass fittings?
    Chris
  • Scott T
    • May 2009
    • 406
    If you don't want to contact OTW
    you might search bicycle or motorcycle cable bellows.
      • 2007
      OTW may be machining their own brass inserts. I just typically use brass tube myself... Bellows aren't' rocket science. Just search for bellows seals on Amazon and you'll find tons of choices.
