Ballast weight.
    • 13687
    Hi David. I used to lay it out in narrow bars on waxed paper until it hardened. I could break off pieces and add small pieces in areas of the hull where needed. Not nearly as clean as your method, but I didn’t have to cook anything in the kitchen to mold them. I like the idea of wheel weights like Rob is showing too.
    Fair enough. Points well made.
    • type7
      • 191
      I use the wheel weights for trimming too but they do rust pretty quickly. The foam tape on them is not very reliable so I usually peel it off and use Goop to hold them in place.
      • Mooneyjock
        • Jul 2021
        • 15
        Great info! Thanks very much. it gives me plenty of options.
