Single motor for 1/72 U-boat.
    • 3621
    HWSNBN,
    what size brushed motor would you recommend for use with Revell Type VII if one decides to go with a single motor driving both props through a counter rotating gearbox?
    • 13841
    HWSNBN,
    380, direct drive. Split.
      • 3621
      Got it.
      Another question, I've seen a Type VII being driven with a single motor driving only one shaft, would the boat suffer from assymetrical thrust?
      • Monahan Steam Models
        • 755
        Got it.
        Yes it would
          • 3621
          From what I've read online and in books ( Das Boot) running on one engine was done to conserve fuel and to do maintenance.
          So I guess they trimmed the rudder(s) to compesate for the assymetrical thrust?
            • 755
            The center line between shafts on a type VII are spaced fairly close together and hypothetically should also be parallel to each other. This reduces the asymmetrical thrust but does not completely eliminate it. So yes a slight rudder adjustment to counter act the thrust would be necessary proportional to the forward speed.
            Personally if the original boat had twin screws then I would make both operational regardless of how many motors it needed. I would not make them individually controlled in a model with such a narrow shaft spacing and parallelism.
              • 3621
              if the original boat had twin screws then make both operational regardless of how many motors it needed.
              I hear you. And less trimming needed.
