Submarines on Patrol
  • biggsgolf
    • Jan 2020
    • 1028
    Do patrolling subs display numbers on sail!
  • CC Clarke
    • Aug 2020
    • 311
    US boats discontinued the practice decades ago to avoid giving away any indication of whom was doing what. Magnetic numbers can be used while inport, in addition to banners on the brow for identification.
      • 13797
      Panted on only during launching, commissioning and change-of-command ceremonies. Before patrol they would even have us grind off the cheat welds that guided one when painting on the numbers. Spooki-poos.
      • biggsgolf
        • Jan 2020
        • 1028
        Great info guys! Thanks
        • biggsgolf
          • Jan 2020
          • 1028
          So I have to ask…. why do most rc subs have the numbers on them?
            • 13797
            Eye-candy. And to enhance your ability to see the thing when it's beneath the surface.
            Boats decked out for patrol did not have 'international orange' painted marker-buoy fairing plates, hull numbers on bow and sail, ships 'name' at the stern, nor DSRV target markings over the escape trunk hatches. And the otherwise shiny MBTV flange-rings and salvage plates were painted black like the rest of the hull.
            I put those markings and colorations -- and that includes 'weathering' -- there to make the model submarine more visible as it travels underwater.
ID:	154220Click image for larger version
ID:	154221Click image for larger version
ID:	154222Click image for larger version
ID:	154223Click image for larger version
ID:	154224Click image for larger version
ID:	154225Click image for larger version
ID:	154226Click image for larger version
ID:	154227Click image for larger version
ID:	154228Click image for larger version
ID:	154229Click image for larger version
ID:	154230Click image for larger version
ID:	154231Click image for larger version
ID:	154232Click image for larger version
ID:	154236Click image for larger version
ID:	154233Click image for larger version
ID:	154234Click image for larger version
            • biggsgolf
              • Jan 2020
              • 1028
              Thanks David
              • biggsgolf
                • Jan 2020
                • 1028
                Forgive me, not sure what the “depth numbers” are called? Are they visible on patrol? Seems like they would give away how “armed” the sub is?
                  • 13797
                  Draft markings. Yes, only numbers and warnings of underwater projections ('PROJ') such as bow planes, horizontal stabilizers and the like are left on the hull prior to deployment on an operational patrol.
                  Boats are trimmed for a consistant surfaced waterline with the auxillery tanks, reguardless of stores, weapons, and personnel load.
                  • biggsgolf
                    • Jan 2020
                    • 1028
                    Goose bumps as I read this!
