Ballast Bulkhead Servo Control Rod Seal
    • Jan 2020
    • 1025
    At the risk of ridicule, how does one replace this seal as mine has a tiny leak depicted by small air bubbles when the valve is opened or closed. It does not leak in nuetral position. Click image for larger version
    • 13627
    Is the leak around the pushrod or around the seal body?
      • Jan 2020
      • 1025
      Hi David, Pushrod
        • 13627
        Hi David, Pushrod
        I'll send you two pushrod seals. Give me your mailing address. dmeriman@aol.com
