X-Tail control yokes
    • 3454
    Looking for photos of the control yokes for the 1/96 Type 212 or Albacore. I know downloaded them years ago but can seem to find it on my phone or laptop. Need it for reference for a 1/144 Soryu I got. Thanks.
    • 13610
    Here you go:
ID:	152012Click image for larger version
ID:	152013Click image for larger version
ID:	152014Click image for larger version
ID:	152015Click image for larger version
ID:	152016Click image for larger version
ID:	152017Click image for larger version
ID:	152018Click image for larger version
ID:	152019Click image for larger version
ID:	152020Click image for larger version
ID:	152021Click image for larger version
ID:	152029Click image for larger version
ID:	152022Click image for larger version
ID:	152023Click image for larger version
ID:	152024Click image for larger version
ID:	152025Click image for larger version
ID:	152026Click image for larger version
ID:	152027Click image for larger version
ID:	152028Click image for larger version
      • 3454
      Thanks boss.
      Also found something else very useful for the Kilo front dive plane.
      Any tips how to remove a CAed Klik-on from the port side output shaft?
        • 13610
        Thanks boss.
        Grab the brass pushrod with soft-jaw needle-nose pliers, grab the magnetic coupler with your twinkies, and twist it. Hard hard is that?!...
        You people!
          • 3454
          Didn't have a soft-jawed needle nose pliers, so I used one of my needle holders.Click image for larger version
          It looks just like a hemostat but has some jaws. It's used to hold suturing needles during surgeries. High end ones even have titanium inserts. This is just a cheap Pakistani one.
          Close up of the jaw. I used a piece of felt to further protect the control rod surface. Click image for larger version
          Success. Click image for larger version
            • 3454
            Smooth jaw
              • 13610
              Smooth jaw
              You did good.
                • 3454
                You did good.
                Thank you sensei.
                  • 13610
                  Thank you sensei.
                  Damned right!
                  The Duke of New York
                    • 3454
                    I still haven't check mine yet but isn't that dumbbell connector for the bow plane servo included in the standard 1/144 Seawolf fittings kit? If not, I'll just fab one from some brass connector block. Click image for larger version
Name:	images (20).jpeg
                      • 3454
                      Turns out the hole that runs through the connector block can accomodate 2 of the 1.6mm servo output control shaft side by side. The 2 screw locks them down tight.
                      Saves me the effort of soldering.
                        • 13610
                        Like so. And also gives you maximum ability to make adjustments on the fly:
ID:	152116Click image for larger version
ID:	152117Click image for larger version
                          • 3454
                          Test fit with some 1.6mm G.I. wire.
                          Test placement on SD
