3D Printing Hollow Bridge
    Thanks!
    Bottom Layers 0
    Flat to bed
    10 Count Brim
    Top Layers 4
    Wall Line Count 5
  • RanSan
    Congrads! How did you get it to print?
    Lower your support density.
    Looking at my support settings is there a way to print less material inside the hollow Bridge?
    Success!
    Great info guys, many thanks. I am using version 3.6.0 as any newer version does not work on my older Macbook.
  • RanSan
    Oh ya don't use spiralise Outer Contour that will only give you 1 wall.
  • RanSan
    What version of Cura are you using? Not that it matters it is just different than the latest.
    I use Wall Line Count and Top and Bottom Layers not Thickness. I have a rough idea of the thickness by looking at the Line Width under Quality? Use that to figure out the rest. For example I use 0.4mm Line Width. My walls are 2mm so 2 / 0.4 = 5 wall count. My tops are 3-5 layers and my bottoms are 0-3.
    Personal perference, I don't use rafting it uses to much material. I like 10 count on brim.
    Hope that helps.
    [QUOTE=biggsgolf;n151308]When using a raft should the Bridge be on the bed or raised above?[/QU
    Flat to the bed!
    Originally posted by RanSan
    What is your setting for Bottom layers in Cura? It should be 0.
    Randy
    Randy, it is 12. What should top layers be? For thicker walls what should I change?
    Thanks guys, I will try using a “raft”. My last attempt is better, using “spiralise Outer Contour” and disabling “Union Overlapping Volumes”. The walls are too thin, lol
  • RanSan
    Randy
    Make sure you are using a raft!
    The STL does not have a solid base
