mobius skipjack center of gravity.
  • BWRIGHT
    • Aug 2020
    • 32
    I'm having a miserable time trying to balance this boat. Where should the center of gravity be? The cylinder im using i believe is the 2 1/2 3 1/2 2 1/2. it is really tail heavy.
    • Jan 2020
    • 1028
    What is it doing? Can you post photos? Are you in first step of trimming at surface?
      • 13838
      Half-way along the submarines longitudinal centerline, as low as you can get it vertically.
        • Jan 2020
        • 1028
        Beautiful video David, yeah seems like you might know what ur doing! Hahahahahah
          • 13838
          Once you establish underwater trim (the boat just light enough to stick one-inch of sail into the air with the boat on a zero bubble-angle) then it's a never-ending ****-show of moving selected pieces of foam above/below waterline till, magically, and to your astonishment, the boat will trim out properly in surfaced trim. Stick with it, you'll get there, pal.
ID:	149450Click image for larger version
          • BWRIGHT
            • Aug 2020
            • 32
            thanks for the replies
