Threaded End or Using a Die To Thread a 2MM Brass Rod
    • Jan 2020
    • 1028
    Hi all, I need to secure or make a M2, isometric thread, coarse (standard), clockwise (standard), parallel brass rod. Only the end of the rod needs be threaded to screw into a prop.
    Any help or sources will be appreciated greatly! Could possibly use a Stainless Steel Rod as well?
    • 2539
    2mm bicycle spokes.
      • 3689
      Andy, that is a cool suggestion......bicycle spoke.
        • Jan 2020
        • 1028
        In had heard of that, but unsure of what threading they have, i.e. isometric, coarse.
        Also need a M3, standard thread, coarse (standard), clockwise (standard), parallel rod...... any ideas? I can have one made from a 4MM rod...... but would need a 4MM to 3MM coupler.
        • Bob Gato
          • 873
          According to the Park Tool website, the typical 2mm spoke has a 2.2mmx56TPI thread. This converts to a 2.2mmx0.
            • Jan 2020
            • 1028
            Thanks Andy & Bob
              • 2539
              The alternative is to cut your own threads, Easy enough to get them parallel if you have a lathe or bench drill.
              • Bob Gato
                • 873
                Here's the easy way out:
                  • Jan 2020
                  • 1028
                  Exactly Bob! Nick @ harbormodels said cannot help with the M3 unless I can use it on a 4mm diameter shaft, if so, he can have his metal guy shear it down and thread it M3. Whatever length I need.
                  • Bob Gato
                    • 873
                    Sorry, man- I saw what I wanted to see!
                      • Jan 2020
                      • 1028
                      No, what you saw is an option, and I need 3mm one as well which he can manufacture for me.
