Moebius 1:72 Scale
    • Jan 2020
    • 1025
    Moebius 1:72 Scale
    Anybody know the approximate turn radius of the Moebius 1:72 Scale kit after RC conversion?
    • 13630
    About five-feet submerged. About twice that surfaced.
      • Jan 2020
      • 1025
      Thanks David!
        • Jan 2020
        • 1025
        David, will my 2.5” Subdriver from my USS Blueback fit in this with the fittings kit?
          • Jan 2020
          • 1025
            • 13630
            Too small a ballast tank, and not enough ass in the motor department. Don't go cheap on us now, pal. Spring for the proper SD!
Name:	DSCF5026 - Copy.JPG
ID:	143860Click image for larger version
              • Jan 2020
              • 1025
              Hahaha, the “WAF”, wife acceptance factor, which my life revolves around is pushing back! I need another build! Need a boat that my Subdriver can be applied.
                • 13630
                Lot's of boats that single-shaft SD will work in:
                1/96 KILO, 1/96 SKIPJACK for example.
ID:	143866Click image for larger version
ID:	143867Click image for larger version
                  • Jan 2020
                  • 1025
                  David, where can I find the 1/96 Skipjack?
                    • 13630
                    I used to produce them. However, they are not currently available (other than the rare estate sale that pops up on EBay every now and then).
                    But, there's hope. My buddy, Kevin Rimrodt, will start early next year taking this and other tooling of mine to produce his line of 1/96 scale r/c submarine kits under the banner, Trident Models. Look for it mid-year.
                    He will also be producing another fine kit that will fit your needs soon -- all he's waiting on is completion of his production facillity which should happend by the end of the year. It's a 1/96 THRESHER class. I did the tooling for it.
                    Here are some shots of the finished model I assembled for Kevin's ad campaign:
ID:	143871Click image for larger version
ID:	143872Click image for larger version
ID:	143873Click image for larger version
                    • Rick Teskey
                      • Jan 2009
                      • 265
                      I will sell you mine for...100, gazillion ...
                        • Jan 2020
                        • 1025
                        David, any other 1:96 boats that my cylinder will fit? Dumb question but how do I obtain a proper conversion kit to assemble the cylinder into another boat? Also, I cannot find a link to Trident Models? Do you have a link?! Thanks, don’t want to b a pain.......
                          • Jan 2020
                          • 1025
                          Thanks Rick!!!!!! Hahaha
                            • 13630
                            Kevin has not yet filed for his business license and tax exempt number, that will happen sometime next year. The Chinese-flu thing has slowed down construction on his new digs. So, no Trident site is up yet. In time.
                            What will fit? Let's see: From the Scale Shipyard, the 1/96 ALFA, and LOS ANGELES; Thor Productions, the 1/96 SEAWOLF, LOS ANGELES, THRESHER, STURGEON, and 1/60 ALBACORE; from 32nd Parallel, their 1/32 Type-23; from Small World Models, their 1/96 BLUEBACK, LAFAYETTE, KILO, and TRENCHANT.
                            Most of the above businesses are no longer in the game but you'll find these things listed on eBay and the like (estate sales, for example). It's an Easter egg hunt. However, be on the lookout for new product coming from Nautilus Drydocks.
                            Fittings kit??? Make your own, damnit!
                              • Jan 2020
                              • 1025
                              Thanks David, I see a few “coming soon” kits from Bob!
