sub 10 esc
  • sublover
    • Mar 2011
    • 18
    sub 10 esc
    i got a question about the sub 10 esc it says you need two 0.01uf capacitors on the motor is that really necessary and if you need them which ones do yall prefer
  • sublover
    • Mar 2011
    • 18
    my bad 0.1 capacitors
      • 13991
      A minimum of two cap's per motor, each made up to a motor pole and motor can (ground).
      Between 0.01 - 0.1 micro-Farad. Ceramic type.
      • sublover
        • Mar 2011
        • 18
        will these capacitors work from radio shack http://www.radioshack.com/product/in...ductId=2062365
          • 13991
          Yup .......
          • sublover
            • Mar 2011
            • 18
            thank you help me alot
              • 13991
              Go get 'em, Tiger!
