Piston ballast tank vs Floating piston ballast tank
  • Monahan Steam Models
    • 755
    Hey Everybody,
    Does anyone have some first hand experience they would like to share using floating piston ballast tanks? I find them interesting because the ballast tank appears to fill and drain similar to the more common screw driven piston tanks but with out the extra space required for the traveling screw. If the performance is close to that of standard piston tanks, it seems like it could be a neat and more compact way to go. Well I guess that is besides the room that would be required for a water pump or two.
    Thanks!
    Nick
    • 755
    An example in this video of what I am referring to as the floating piston ballast tank type. This one is neat because it is a twin cylinder on one pump set up. The more common ones I’ve seen are single pump single cylinder.
    My experience has mainly been with vent and sink, blow and go pressurized gas ballast systems besides some miniature dynamic divers I built as a kid.
    Looking at adding smaller piston type set ups mainly for additional fine trim control and depth control.
    Video: https://m.youtube.com/watch?v=cBMO-EMTEJ0
      • 3381
      Aren't floating piston ballast tanks just essentially water pump/ bag ballast system but you swap out the bag for a syringe. Looks neater than a floppy bag but still has issues with internal pressure build up.
        • 755
        Yeah, that was what I was curious about. Seems like the same pressure problems of a regular piston cylinder only more compact in the way I was thinking of using it and happier to see ya then a floppy water bag. I would think it would still give the same fine ballast adjustments if kept small and used in conjunction with a larger main tank as a secondary trim control
          • 3658
          I am working on a piston system for the Gato and may try the floating piston. I have an WTC from small world models and it uses a floating piston.
            • 755
            Trout,
            Thanks for posting. Is your SWM’s wtc functional? Have you had a chance to test it?
              • 3658
              Yes, I played with it. The design as a whole is OK, but it is designed like the New SubDriver in that it uses modular sections. These leak a lot on this WTC I have (meaning the SWM WTC) and I did not trust it for use. That being said, the piston moved fine and pressure build up was not an issue. My 3.5" piston on the other hand is 19" in length and has a 2.5" piston with 7" travel. It does build up pressure, but that is still manageable. The pushrods use a simple o-ring in a compressing type mount. That holds back air from leaking just fine. Future ones I build will not be that compact, it was more me seeing if I could.
                • 755
                That’s great feedback and exactly the info I’m looking for. Thank you!
                  • 2414
                  Wasn't aware that SWM did a pump based piston type module- they tended to use fixed tanks with propel/gas.
                  RPMtech and RCsub workshop did pump based piston modules.
                    • 3658
                    Andy,
                    you are correct, I mixed up names, it was Rick Palumbo’s system (RPMTech). Thank you for catching that!
                    peace,
                    tom
                      • 1937
                      I used that style of actuation for my periscopes in my current Type XXI build. I'd hazard a guess that a pump-based system like this would draw more current than a screw-type piston system, but that's just a guess. Making your own large-diameter ballast tank with this methodology shouldn't prove to be too difficult. If the pressure buildup is too large, I wonder if it would force the syringe back in and flow water back past the pump if you didn't use a valve to close the line. Not a problem if you went with a peristaltic pump, but if you used the higher flow gear pump, it could be an issue.
                        • 755
                        Bob, I’m hearing what you’re saying. I was thinking on a smaller scale about trimming for torpedo loss after launching mainly in the forward section
                          • 3658
                          Perfect use for a small piston, for that matter, it is a fixed weight, so a piston using a plane retract setup would work, like I did on my 1/96 scale Aluminaut. Love your thinking there Nick!
                          This gets my mind thinking in that when you launch it simultaneously moves piston or the piston motion triggers the launch.....oh the possibilities.
                            • 755
                            Trout I like your thinking!
